Page 2 of 15 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 218
  1. #16
    Question Connecting Dreambox
    Hi, can I connect dreambox with eathernet cable?
  2. #17
    Quote Originally Posted by raheel59 View Post
    yes you can, but I would have used Flashwizard then....
    Normally I use FW, because then i can flash boxes via LAN or even WAN but you need a really good line then....
  3. #18
    Apr 2009
    Thanks. Got me out of a real hole.
  4. #19
    May 2009
    Default Another thank you
    Sincere thanks for explaining the job so well and making it straightforward . My DM500 stopped working after power supply failed and wouldn't boot with a replacement ( CCTV 2A 12v recommended elsewhere on this forum )
    Ethernet port wouldn't open so used Dream up but found although reflashing went ok box still wouldn.t get past the splash screen on PLi Jade 3 or Digital Kaos 1 or 1.1 .
    Successfully flashed with older version of Pli Jade ( clogged up RAM ? )then did factory reset and upgraded via LAN . Very many thanks for all the help and Happy New Year
  5. #20
    May 2009
    Default new to this
    hi i'm new to this satallite thing, i've done alot of eurovox boxes but i like to learn about satallite one.
    so basicly does it work to same as a eurovox but going through sat-dish and that you get the same channels aswell?
    hope u can help, would very gratefully
    many thanks
  6. #21
    V.I.P. Member opsmonkey's Avatar
    Nov 2008
    var/etc
    Quote Originally Posted by funkysy View Post
    many thanks
    its nothing like cable mate.. its way more complex.. sat is not just FTPing a few files over..
    if you are after Sky UK forget it its not open and never will be..
    the encryption on sat is higher end
  7. #22
    Hi, I'm having hard time with my DM500 only showing a green light with no responce what so ever , well dreamUp help ? and how wold I know if the flash its self is damaged or not ??
    If some one can help please!!!
  8. #23
    May 2009
    Quote Originally Posted by opsmonkey View Post
    so you can't get any sky channels with these boxes then!!!!!!!
  9. #24
    Bulld0g's Avatar
    Apr 2008
    Liverpool
    No. It's not like cable as has already been stated.
  10. #25
    Bulld0g's Avatar
    Apr 2008
    Liverpool
    Quote Originally Posted by eastriver View Post
    Reflash the box . It might be a bad flash.
  11. #26
    hi guys does anyone got a gemini 4.5 link or the gemini 4.6
  12. #27
    Bulld0g's Avatar
    Apr 2008
    Liverpool
    Quote Originally Posted by dahsissa View Post
    Have a look and see what here m8 Digital Kaos - Downloads - Images
  13. #28
    I have recently bought a DM500S.
    i installed PLI image and evrything worked great.
    the first moment i tried to install some app from internet on it, it freezed for a moment and did not respond any more.
    i tried to reset it pluging out the power supply but when i reinserted power it did not respond any more.
    the lightindicator turns on green but nothing appears on tv.
    trying to acces it from my pc via ftp, no response from it.
    trying to flash it, still no response.
    Please Help, is there something i can do to revive it or i must buy an other one?
    please PM me or post here
  14. #29
    hi all, I'm new to dreambox.. I looked around for some answers around the net.. but I couldn't find the answer till now... the question is: from where does the box get the fresh codes, and is it an automatic process for update?.. thanx
  15. #30
    Quote Originally Posted by ahmadzaineldin View Post
    You will need a sat card, or start CS (witch is illegal) to get codes.
    There is also possibilities to have a small SW that is updating files on your DB (also illegal)
    But, if you have a card from any provider, it is enough to have a cam om your DB to update it so it can read your card.
    Fex; MgCamnd/NewCS (PS: this is not cardsharing CS to use this)
