Hi, tried this... but all i get is err01 in the osd disp.
The flash upload is complete, but it says "initilazing".
Any tips?
###UPDATED###
Just changed dream up version 1.3.3.5 to 1.3.3.2 and everything seemed to be working.
Any tips?
###UPDATED###
Does any find this slow? It's taking 60mins to flash a box (dm800)
The green light on my box keeps on all the time. I removed all the wires, reconnected them. checked for loose connections. kept the box off for few hours but nothing seems to be working.
Guess i need to flash via dream up? Guide me if i am wrong or if someone has a alternative solution
After changing skin on my 500c it simply refused to boot properly afterward. I can ping it, but neither FTP or telnet works, so no possibility to manually clean the mess.
Hopefully this will work...
Could windows 7 be a reason why i am not able to connect to my DM via Dream up ?
In the enigma 2 you can go in settings file in tuxbox and clear the default skin text to "" from "skinname" and it will boot up with the standard skin.
Im affraid in dm500s/enigma 1 you will have to do a reflash by rs232 port, since LAN function is not loaded when skin causes errors. FTP or DHCP is not working. Only way to connect box is the hard way ..
Hi, I am new to dreambox. I bought a dreambox 500s with a Gemini version 1.0.8 and tried to ugrade it to Gemini version 4.7 using Flash Wizard 4.0, but it went wrong and the Flash Wizard Pro was hanging for about an hour and had to abort. I think now I have lost the image on the box, it doesn't reboot, so I guess I have to reflash the image. I have couple of questions if someone can help please:
1) Which Gemini version is better, stable and clone proof ?
2) Is there any other image better and popular than Gemini ?
3) Do I have to install any other plugins other than CCcam to bring it back to operation ?
3)
I have the same problem as some of you.
Trying to flash my dreambox with dreamup.
After 20 seconds the message ?aborted by user?
What to do???
Does anybody knows is there Linux-based and DreamUp-styled applications available anywhere?
