Please how long does it take to flash a DM500S with pli jade image? Mine is taking forever!
i have to say a big thanks to the man that he give out the instractions, on how to flash with a null cable..
i have to say that before i destroy 2 dbox. becouse i was trying to find a hard where problem... but actualy was a softwear... the infos are 100% corect. if you have any problem this is mean that your dm is bad, or cable is not correct. i have made my cable. is only requere 3 wires...
thanks once again..
New to this site. Very informative website on various configuration information and various updates. Good stuff!!!
hi im new to this iv just got dreambox 500-s done a lot of reading so i think i know how to use dreamup but how do i get hold of an image
Be careful if you are doing it to a DM 800 - I accidentally selected an image for a DM8000 and stuffed it up !
Could you not re-flash with a DM800 image?
Flashed dm 7025 for first time with pure flash (cf card inserted) using DreamUp and then nabilosat .11, but there was no option where on the box to install it. I take it the pure flash found the cf card and the nabilosat image was installed in the multiboot (wherever that is) and not just re-wrote the cf card wiping out the pure flash. How would I know?
Now flashed OK, What do I do now? In the setup, or in the Internet settings, which site to visit and have access to...??
I wish to recieve Norwegian TV actually ViaSat or CanalDigital
Even dont know how many degrees and where to point the dish, so i`m pretty new here,.- pls reply to vishkinjohn(a) gmail.com o r yahoo.com
Many Thanks
You need to go into system then network and set up your network.
Connect your ethernet to your router,Your Dreambox can be almost what you want it to be so if your router ip is a Belkin and its 192.168.2.1 make the Dreambox 192.168.2.11 or any digit but have dhcp crossed out.
The gateway and nameserver ip should be the same as the router.
Post back what router it is and go from there.
Andy.
what is the best software for dm500s v8
Can anyone help , getting connection prepared , now switch on dreambox, i switch it on noyhing happening , any ideas folks
thx
what dreamup is best to flash dreambox 500s
Tried this method. Everythhing goes according to plan... then approx. 20 seconds nito flash upload, an info. box appears "ERROR.... Aborted By User, Exiting and the upload stops. Tried three different p.c.'s, null modem cables, different images etc. but still the same. I noticed that I had to keep the ethernet connection plugged into the router for the box to give back the message "box is alive and talking to us".
