Page 1 of 15 12345611 ... LastLast
Results 1 to 15 of 218
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    Default Guide: Flashing a Dreambox with Dreamup
    How Do I Use Dreamup?
    If, for any reason, your box won't boot, you will have to use Dreamup to flash an image instead of Flash Wizard Pro or any other method. You won't be able to connect via ethernet so no ip address is required. It may be that the process simply hung up during flashing or you accidentally pulled the plug half way through (yes it did happen to me). This will get you back on track.
    Required
    • Null Modem Cable (this is NOT the same as a serial or rs232 cable, although it looks the same)
    • Image File (.img)
    • DreamUp Program
    Instructions
    • Disconnect all cables from your dreambox, including the power
    • Connect the null modem cable to the dreambox and to your PC
    • Load Dreamup.exe
    • Click Connect and you will see a message like this
    • Connect the power and the bootloader should be copied to the box
    • The message should now say 'Box attached and Ready'
    • Click Flash on the right hand side and select the image to be flashed
    • Click Yes or Ya (depending on the version)
    Note: If you're flashing a backup image, select NO.
    • The image should then be uploaded to the box
    • There will be a countdown timer at the bottom of the program
    • After the image is uploaded, it will be flashed to memory
    • The finished process should look like this:
    • Click OK and close down Dreamup
    • Power off the dreambox for 30 seconds then power up
    • If any errors appear, check all cables are connected properly and repeat the process but do not use the PC while it's running
    Good Luck!
    Get Digital Kaos on your Apple or Android device with Tapatalk
  2. The Following 3 Users Say Thank You to Devilfish For This Useful Post:
    mesko6256 (5th July, 2019), zulky (8th December, 2013)
  3. #2
    V.I.P. Member opsmonkey's Avatar
    Nov 2008
    var/etc
    cheers DF.. a welcomed addition to the DB sat section..
    May 2009
    Can some one show me how i can upload the Cccam 1.2 files on dm500s.
    Many Thanks
    Aug 2009
    Default thanks, what next
    ive done the dreamup with darkstar2
    i connected box to router with ethernet
    dloaded cccam2.0.10
    then added satanbundle
    and alas nothing
    im missing something?
  6. #5
    Aug 2009
    have you dloaded cccam via addons menu
  7. #6
    Jan 2009
    hi mate wanering if you can point me in right direction my mate got sky and just bought a dreambox can you tell me what i need to do to it to get channels ive done it for cable no probs not sure if same for sky cheers m8
  8. #7
    Jul 2009
    Default cccam
    Anyone know how i restart the cccam wont give me the option by holding down the info button
  9. #8
    Mar 2008
    Quote Originally Posted by dsledge View Post
    If using dk1.1 just hold info button for 3 secs will do it.
    Setup: 2x Dreambox 800HD | 3x Dm500S on Motorised dish Setup
  10. #9
    Jul 2009
    Norway
    Default DM600
    Hi all!
    I flashed E2 (newnigma2) into my box before last weekend, and it worked fine. However it took ages to boot, and I tried a few days ago to flash my "old" Gemini 4.50 image back as that has been working without problems for a long time.
    My problem is that the box won't connect to DreamUp. Both lights at the front are on (the red and the green), but it is strange I cannot connect from my pc to the box. When I click the Flash-button and connect the AC, the box don't return any signal, and the connection stops where it says "connection prepared, please switch on the Dreambox". It won't go any further than that.
    I hope I haven't done anything wrong, but can anyone shed some light as to what I can do? All help most appreciated. I've spent a few nights trying to sort it, but I can't find anything on the net that helps. Thanks!
    Bard.
  11. #10
    Default Using dream up
    Hi guys , I am trying to upload a new image on my DM500+ with dream up utility and after i do the process the result is always the same Ivalid flash and the dream box will be unusable now . can some body tell me what I am doing wrong .I checked all the cables and all is good
  12. #11
    Bulld0g's Avatar
    Apr 2008
    Liverpool
    The image might be corrupt. Try downloading it again or try a different image
  13. #12
    Nov 2009
    Default dreamup
    [QUOTE = Devilfish; 217222]Comment puis-je utiliser DreamUp?
    Si, pour une raison quelconque, votre bo?te ne sera pas de d?marrage, vous devrez utiliser DreamUp ? clignoter une image au lieu de Flash Wizard Pro ou toute autre m?thode. Vous ne serez pas en mesure de se connecter via ethernet si aucune adresse IP n'est n?cessaire. Il mai ?tre que le processus tout simplement raccroch? au cours de clignotants ou vous avez accidentellement appuy? sur la prise ? mi-chemin ? travers (oui ce n'est pas arriv? ? moi). Cela vous mettra sur les rails.
    N?cessaire
    • Null Modem Cable (ce qui est PAS la m?me chose qu'une s?rie ou un c?ble RS232, bien qu'il semble le m?me)
    • Image File (. Img)
    • DreamUp Programme
    Instructions
    • D?branchez tous les c?bles de votre Dreambox, y compris le pouvoir
    • Branchez le c?ble null modem ? la Dreambox et ? votre PC
    • Load Dreamup.exe
    • Cliquez sur Connect et vous verrez un message comme celui-ci
    • Branchez l'alimentation et le chargeur de d?marrage doit ?tre copi? dans la bo?te
    • Le message doit maintenant dire ?Case-joint et Ready '
    • Flash Cliquez sur le c?t? droit et s?lectionnez l'image pour ?tre flash?
    • Cliquez sur Oui ou Ya (selon la version)
    Note: Si vous ?tes clignoter une image de sauvegarde, s?lectionnez NO.
    • L'image doit ensuite ?tre envoy? ? la bo?te
    • Il y aura un compte ? rebours au bas du programme
    • Lorsque l'image est t?l?charg?, il sera flash? ? m?moire
    • Le processus final devrait ressembler ? ceci:
    • DreamUp cliquez sur OK et fermer
    • Eteignez la Dreambox pendant 30 secondes puis mettez hors tension
    • Si des erreurs apparaissent, v?rifiez tous les c?bles sont branch?s correctement et r?p?tez le processus, mais n'utilisez pas l'ordinateur pendant qu'il est en cours d'ex?cution
    Bonne chance![/ QUOTE]
    Bonjour,
    pa possible telecharger le ficher.. possible me envoyer par E-mail.. merci
  14. #13
    Nov 2009
    What is wrong? I`v got initaling H T T P or something and nothing is happining....?
  15. #14
    Dec 2009
    Hi all,
    New to the site and am amazed at all the info supplied.
    I'm trying to flash a DM 500S, however I'm having some difficulty.
    Firstly, when I open Dreamup, there are only three commands, Connect/Disconnect, Flash and Exit in the Command section. There is no Ping etc commands so have I got a correct Dreamup version?
    Secondly, when I connect to the box via a null modem cable, I get the following in the log:
    16:12:49 box type: DM500
    That's as far as I can go as the Flash button is shaded and can't be used and I get no activity in the Progress bar.
    Any thoughts?
  16. #15
    Dec 2009
    Turns out that my cable was not a true null modem cable, so got a proper one and all is working
