For get code you need to read 93c46.................
Have you got picture of the location of the eeprom on the board maybe ?
See..................................
Can't read in circuit :/ overload protection when I try to read .Do I have to remove the eeprom
I have removed the eeprom and read it all 00
Does any one have dump with known code?
Can I use dump from Nissan Pp-1675H ?
BUMP need some help
friend 93c46 rotated ,Read
Check the main board connections eeprom, maybe eeprom is rotated!
BusCan (8th July, 2021), Dziwak (19th July, 2014), mcd76 (18th July, 2014), osman ?elebi (18th July, 2014)
the eeprom is fairchild 93c46 and when i try to connect it rottated programer says that over current protection
proğram device,Microwire eeprom support , to try another eprom,eprom may be damaged ?
Dziwak (18th July, 2014)
I have readed rotated the eeprom
can i have a code?
Dump.rar
Is it 5148or 4851 ?
sorry about being little bit dumb , weather in UK is killing me today
Can not you check where is +5 V and where is GND, and an
tell what your eeprom??
I have readed the eeprom as 93LC46X
It's first time i work on rotated eeprom and I dont have massive exprience yet . sorry
Sorry, I have a problem with the internet and therefore receives misunderstanding!
try code4851
masterskay62 (19th July, 2014), mcd76 (19th July, 2014)
Sorry to bother you are u able to reset error counter in the dump , Radio is displaying Secure I will leave it on for few hours but would prefer to check if the code is correct straight away.
I have searched arround and Secure is kind of can check
