Page 15 of 21 FirstFirst ... 51011121314151617181920 ... LastLast
Results 211 to 225 of 303
  1. #211
    bursuc's Avatar
    Oct 2011
    inside MCU
    Need help with VW T5
    ABS ecu no communication.
    All power supply is there. There are 2 IC on this board
    990-9393.1. ATE
    SC550078MFU42
    Here are pictures. Maybe somebody can give me a hint.
    Thanks in advantage
    Dosen't matter how hard is to repair something as long is made by humans and thinked by humans !
  2. #212
    Dec 2011
    Anyone who knows replacemet mosfet for Bosch 8.0 ABS unit? I have a DTC regarding the pump, figured out that the P80NS04ZA transistor is dead but unfortunatelly I cant find it at any supplier.
    Any suggestions for replacement?
    Thanx
  3. #213
    soxten's Avatar
    Mar 2013
    Quote Originally Posted by bursuc View Post
    990-9393.1. ATE
    SC550078MFU42
    Thanks in advantage
    Resolder both mcu!
    Skickat från min iPhone med Tapatalk
  4. #214
    right here right now
    I have a 2008 Renault Laguna 3 with ATE unit 476600016R which is giving a fault for pump motor circuit and the fault is in the hydraulic block as it's a known fault on these cars so just wondering if anyone here has any experience of repairing these units rather than replacement.
    Sent from my SM-G920F using Tapatalk
  5. #215
    Feb 2017
    United States
    So Whats the deal with the kelsey hayes 325 modules having the abs motor run all the time. Is it the relay or something else. Thanks for the help as i mostly just resolder for the brake light and abs light.
  6. #216
    Feb 2017
    United States
    ok so i have done some research that it is more than likely the mosfet i hear there is a better mosfet to replace the old one with. Does anyone know which one that may be?
  7. #217
    hello all fiat linea 2010 abs light on and dtc C1108 serial connector on all time tryed with two second hand unit no help and tryed adapt with multiecuscan no help either, has any one else had same problem before
  8. #218
    hi, i got bmw e46 ecu with 5df5 error , have you some infos about this repair?
  9. #219
    soxten's Avatar
    Mar 2013
    Resolder both mcu and all pin on left side
  10. The Following 3 Users Say Thank You to soxten For This Useful Post:
    Faraday (7th October, 2021), marcoco (9th February, 2019), rochinha75 (2nd March, 2021)
  11. #220
    Oct 2015
    Quote Originally Posted by giova71 View Post
    For soxtein
    hello i have identical problem with nissan qashqai. the ABS pump engine is constant runing.
    the link gives me " 404 file not found "
    you can post it again or put a picture please
    thank you
    Anyone have info about how to repair this?
  12. #221
    italy
    hi evribody. someone konow haw can repair abs vw ate mk 61 with error 01130 ABS OPERATION. IMPLAUSIBILE SIGNAL.
    I see thet ACTRONICS and ECU-TESTING can repair thet. someone have an experiance with tis module?
  13. #222
    McDowell's Avatar
    Feb 2019
    Zamunda
    Hey, i´m not sure if you guys know about this Jaguar pinout, I´d like to diagnosis it via OBD
    Attachment 614359Attachment 614360Attachment 614361
    Thanks so much in advance
  14. The Following User Says Thank You to McDowell For This Useful Post:
    alclot (13th June, 2019)
  15. #223
    dd1's Avatar
    Aug 2014
    Hello to everyone, mbz c w204 or s w221 abs control module internal fault code, its a mk61, if i am not mistaken, by ATE. What is the repair solution for this units???????! Thank you in advance
  16. #224
    dd1's Avatar
    Aug 2014
    By the way this is what the pcb looks like
  17. #225
    Oct 2015
    Quote Originally Posted by dd1 View Post
    ur car solve already??
