How to repair ABS system and units thread (repair,help,questions) - Page 2
Page 2 of 21 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 303
  1. #16
    soxten's Avatar
    Mar 2013
    Here is a ABS unit to Opel Vectra B
    TRW 13216601
    S108196002L
    See my pitures how to open.
    This get bad solder points as I show.
    Resolder and seal top hood back on abs unit and run
  2. The Following 4 Users Say Thank You to soxten For This Useful Post:
    armpower (14th March, 2015), gomarota (11th November, 2014), mexanico1971 (14th September, 2016), PierreTheron (9th February, 2016)
  3. #17
    EU
    Quote Originally Posted by soxten View Post
    Here is "G201" brake pressure sensor
    It is a hell to take a way, but with special tools it's ok.
    Where can I buy this pressure sensor?
    Hi. What tool did you use to take ot the sensor?
    I had one unit with same problem, i have sent it to BBA-Reman, after the repair i have opened the unit to see what`s changed.
    The surprise was ,that the old sensor was still there ( i have made a mark on it), the ECU was not open, so my question is : What did they do?
    The unit works again and no Brake pressure Error.
  4. #18
    soxten's Avatar
    Mar 2013
    Ollync, what, It looks like I am wrong.....
    This sensor is a hell to take a way, use small toll to put under sensor and then change to bigger tool when sensor is coming up a bit.
    BUT please put pictures on your fix'd abs unit up here.
    Christian Johansson via Iphone 5s
  5. #19
    DK Veteran thomas76's Avatar
    Oct 2010
    possible cleaner with ultrasonic solution on hydraulique
    Electronic Automobile
    If post usefull press
    "THANKS"
  6. The Following User Says Thank You to thomas76 For This Useful Post:
    Meat-Head (16th May, 2020)
  7. #20
    EU
    Hi.
    Pictures i have none, i had to mount the unit back to the car quick because the owner needed the car.
    I don't think they have cleaned something. The DTC was C0131 pressure sensor circuit, something electrical....who knows.
    I will buy one second hand unit and i will try to take out and disassemble the sensor and dig more...
    Searching the internet i found this.... http://www.lpkf.com/newsletter/lds/925/929/291.htm
    The sensor looks pretty much like the one in the MK60 unit.
  8. The Following User Says Thank You to ollync For This Useful Post:
    mexanico1971 (10th November, 2014)
  9. #21
    soxten's Avatar
    Mar 2013
    In this sensor it look's a litle bit diffrent.
    If someone has a new or working abs unit in stock please mesure ohm on connections so we can compare to my broken.
    It's a hell to disamble the sensor and not distroy it....
    How do the fix the sensor by not removing it... ??? Hm...
  10. #22
    soxten's Avatar
    Mar 2013
    Is it a simple way to fix this... Does the sensor "hang" it self in open or closed way so if you flush the channels in abs unit so the sensor get clean in this oil channel?
    ... Hm....
    I need ohm test from a working sensor, please help!
  11. #23
    Oct 2010
    This sensor is DEAD
    Fault : C1302
    Tomorrow i clean group hydraulic with solution ultrasonic
    "THANKS"
  12. The Following 13 Users Say Thank You to thomas76 For This Useful Post:
    antwnhszr (4th January, 2019), bawareca (14th January, 2017), denis1hr (2nd December, 2019), einet (4th November, 2014), martinracing (10th November, 2014), Meat-Head (16th May, 2020), mexanico1971 (10th November, 2014), okomar (6th March, 2015), soxten (4th November, 2014), speedservice (28th July, 2016), vavrich (10th November, 2017), violator11 (5th November, 2014), xifly18 (11th December, 2015)
  13. #24
    Aug 2011
    Hi, I have here fault ESP MK60 from Peugeot with same fault ... and the difference in resistance is +-0,02 Mohm but the resistance in Kohm is different your is 13,2 mine is 8,74 Kohm. I'm interested in this ultrasonic solution too because I change a lot of hydraulic blocks on VW because of this fault.
    regads
  14. #25
    soxten's Avatar
    Mar 2013
    I have some broken abs units at my place now and find out that ohm is diffrent on every one....
    And it is Inpossible to take sensor out from alu.block with out making scratchs and marks on sensor and alu.block.
    It is fitted hard! In alu.block!!!!
    Only way that they can repair this units is by flushing sensor cannels!
    So we need to build a test bench so we can know "when" sensor is working again.
  15. #26
    soxten's Avatar
    Mar 2013
    Hm... What channels is passing the sensor?
    We have 6 connections on alu.block.
    The sensor has one opening to get fluid in to it, and in that opening you find a hole in the wall 90degres
    [IMG]http://tapatalk.imageshack.com/
    v2/14/11/04/5607a63c1ec94e7c53cce2fdfaf59623.jpg[/IMG]
    Looks like a gel is the connection when pressure in system.
  16. The Following 3 Users Say Thank You to soxten For This Useful Post:
    armpower (14th March, 2015), okomar (6th March, 2015), sazimam11 (21st January, 2016)
  17. #27
    soxten's Avatar
    Mar 2013
    Default How to repair ABS system and units thread (repair,help,questions)
    Okej.... When you take it apart you brak small alu wire as is connected to pcb
    At the bottom of the hole in to sensor there
    is a "gel" as I think is making conntact when presure is on or off.
    Not easy to take a photo thru microscope and my mobile )
  18. The Following 3 Users Say Thank You to soxten For This Useful Post:
    armpower (14th March, 2015), cseko (10th November, 2015), Stelaras (24th November, 2017)
  19. #28
    soxten's Avatar
    Mar 2013
    I think the connection-gel in the hole to sensor is the problem.
    A clean out by ultracleaner can fix it.
  20. #29
    soxten's Avatar
    Mar 2013
    Stop!
    It is no gel! It some shit as look like gel!
    I have now find a small metall tube inside as moving in the hole!
    It must be this as get stocked in the hole.
    Here you se the ends of the metall tube
  21. The Following 2 Users Say Thank You to soxten For This Useful Post:
    mexanico1971 (10th November, 2014), Stelaras (24th November, 2017)
  22. #30
    Jan 2011
    hi what solution are you using in ultrasonic cleaner to clean the abs pump been looking for a while but cant find a solution also is there any for cleaning the gel of the ecu side
