Page 3 of 21 FirstFirst 1234567813 ... LastLast
Results 31 to 45 of 303
  1. #31
    soxten's Avatar
    Mar 2013
    New update
    The metal tube inside the hole is NOT moving!
    I have cut it up and the tube is a bart of the constructions.
    So I did not find any broken lines,parts in the sensor.
    I think the problem is the gel as is in the bottom of the hole as keeping the presure to be korrekt to the sensor-wall.
    PLEASE if some one can find what opening in the alu.block as going to the sensor, then we can maka a small tube/line and try to clean out the gel and see if it works.
    AND do we have some clever guy as can look at the wireing to abs unit, then we can connect it to OBD and try to find a way to fix this.
  2. #32
    Lithuania
    Connect to obd or diag is easy. I try post maybe tomorrow.
    Any one have fixed staking pump motor problem, then have errors about pump motors plug or pump motor.?
  3. #33
    soxten's Avatar
    Mar 2013
    Lagas: it is fault in transistor, see my work in the Rover abs unit in this thread.
    It take 1 hour to fix!
    Christian Johansson via Iphone 5s
  4. #34
    Lithuania
    Default How to repair ABS system and units thread (repair,help,questions)
    Have bmw one. Transistor big one not helping, thing it is maybe ATE driver, but funny think if ju hamer abs unit or motor it spins for 2-3 activations and then error. Try put other motor with compleat al hydraulic same but spare unit work with both motors.
    Ps.have many of this problem
  5. #35
    soxten's Avatar
    Mar 2013
    Is it bmw bosch "...001"?
    This have always bad connections/broken alu.wire.
    I did 2 last week.
  6. The Following User Says Thank You to soxten For This Useful Post:
    keesg60 (19th July, 2017)
  7. #36
    Lithuania
    No no, this ones is ATE i uplaud late on photos
  8. #37
    soxten's Avatar
    Mar 2013
    Please upload photo on ate unit.
  9. #38
    Lithuania
    there is the unit.
    usually you get fault's:
    005D F1 : DSC Hydraulic unit: pump motor
    00A8 AF : DSC Hydraulic unit: pump motor connector faulty
  10. The Following 2 Users Say Thank You to lagas For This Useful Post:
    luis12 (21st February, 2019), nedved59 (28th February, 2016)
  11. #39
    DK Veteran thomas76's Avatar
    Oct 2010
    Ultrasonic solution not work
    Electronic Automobile
    If post usefull press
    "THANKS"
  12. The Following 3 Users Say Thank You to thomas76 For This Useful Post:
    beli123 (21st May, 2016), Meat-Head (16th May, 2020), monir1999 (17th August, 2023)
  13. #40
    soxten's Avatar
    Mar 2013
    How big ultrasonic machin did you use?
  14. #41
    Aug 2011
    Quote Originally Posted by thomas76 View Post
    I try this too ... but without sucess.
  15. #42
    Aug 2011
    Quote Originally Posted by soxten View Post
    100W, I try to use different fluids and to leave it in machine for over 1h ... the resistance is changed but the fault is still present
    when I will have more time I will try again and post mesurment ... but for now I solve problem with new unit
    regards
  16. #43
    soxten's Avatar
    Mar 2013
    I have order a new 400w with heating to test this.
    Did you put a lock over sensor before cleaning?
  17. #44
    Oct 2010
    10 L ultrasonic machin
    "THANKS"
  18. #45
    soxten's Avatar
    Mar 2013
    If it's no cleaning solutions... Where is the sensor problem?
    Pipina: what is the ohm on new unit?
