Page 13 of 21 FirstFirst ... 389101112131415161718 ... LastLast
Results 181 to 195 of 303
  1. #181
    Feb 2011
    look this sensor LPKF:
  2. The Following 2 Users Say Thank You to papyrusse For This Useful Post:
    mexanico1971 (18th April, 2018), Rollaass (22nd August, 2022)
  3. #182
    soxten's Avatar
    Mar 2013
    Correct that sensor is a newer model
    Skickat från min iPhone med Tapatalk
  4. #183
    Feb 2011
    this pressure sensor is very similar
  5. #184
    Feb 2011
    Where are you from Soxten?
    I am from France
  6. #185
    soxten's Avatar
    Mar 2013
    Same as your picture as before.
    This is a newer modell
  7. #186
    Feb 2011
    It's toot difficult to clean.
    I think it should be change
  8. #187
    Feb 2011
    Do you have a bonding machine?
    F&K Delvotec is very expensive
  9. #188
    Dec 2013
    Anybody know where to get a 95042U3 chip from, looking at STs website its a discontinued product. What can replace it ? cant find the datasheet anywhere.
  10. #189
    soxten's Avatar
    Mar 2013
    You cant change sensor.
    If tou try to take it away you destroy the hole in alu.block.
    You need to repair it by opening sensor up and then repair broken alu wire.
  11. The Following User Says Thank You to soxten For This Useful Post:
    Faraday (30th March, 2020)
  12. #190
    Nov 2017
    Shenzhen
    Hello everyone
    I read this thread completely
    Many customers find me and ask me this sensor
    Recently
    I have already asked my friend
    If he finds 2PCS new sensor, original, working
    He will send it to me
    I study it, and then make it
    If later, on this sensor, do not understand where I ask you, I hope you give me some help
    Because I found a lot of people are very familiar with ABS ATE MK60 sensors, and have a wealth of experience
    Sorry, I'm bad English
  13. The Following User Says Thank You to David sun For This Useful Post:
    soxten (19th December, 2017)
  14. #191
    I have Mazda 3 with ABS error C0020.
    Alredy checked power supply and ground to ECU. All ok.
    In this car sometimes ABS light is OFF and ABS works correctly. Other times ABS is on with error C0020 and ABS don´t work.
    Should I solder all components on the pcb ? Or its other problem ?
    Check the photos:
    Thanks for your help !
  15. #192
    soxten's Avatar
    Mar 2013
    Solder all pin on left side
    Solder all pin on mcu
    Use hot air to resolder all other component on pcb, but dont heat components with plastic on!
  16. The Following 2 Users Say Thank You to soxten For This Useful Post:
    aqua_life (26th December, 2017), mexanico1971 (18th April, 2018)
  17. #193
    Thanks for your help.
    When you say to solder left pins, should I solder the connectors pins that goes to pcb ?
    From factory these are not soldered.
  18. #194
    soxten's Avatar
    Mar 2013
    Quote Originally Posted by aqua_life View Post
    Correct! Solder this to pcb!
  19. The Following User Says Thank You to soxten For This Useful Post:
  20. #195
    Jul 2016
    USA
    need help to repair 2004 Chevrolet Impala ABS Module.
    "Service Traction System" comes up, and ABS and Traction lights come up
