Page 17 of 21 FirstFirst ... 712131415161718192021 LastLast
Results 241 to 255 of 303
  1. #241
    990-9377.1C tray replace
  2. The Following User Says Thank You to janusz21 For This Useful Post:
    dijo (25th November, 2019)
  3. #242
    dijo's Avatar
    have you solved this way...?
  4. #243
    I haven't always exchanged for ESP/BA na CDC/ADAM see pm
  5. #244
    Mar 2016
    Suzuki Splash
    06.2109.5293.3
    06.2102 1311.4
    The pump is not communicating with the ECU. Cannot be diagnosed. No communication. Current consumption 100mA. MCU resolder.
  6. The Following 2 Users Say Thank You to zonkil For This Useful Post:
    joze (23rd November, 2020), mexanico1971 (16th March, 2020)
  7. #245
    soxten's Avatar
    Mar 2013
    Have you resolder both mcu pin by pin?
    Skickat från min iPhone med Tapatalk
  8. The Following User Says Thank You to soxten For This Useful Post:
    alclot (13th December, 2019)
  9. #246
    Dec 2019
    I have found blown IC 9369.1D with 14 pins. This is on my BMW mk60 part number 6759075. Error was 5df5 internal error. Have found a replacement IC from eBay and will try to repair.
  10. #247
    alclot's Avatar
    Melee Island
    Hi mates,
    I tried to repair one abs vag like this one. I resold mcu but gets the same dtcs 0 1130. Any tip to fix it? Is there a way to check this dtcs on bench after repair?
    Thanks a lot
    Quote Originally Posted by brchip View Post
    Hello, I need help with this one. I soldered all points already but still it won't work.
    I noticed that with the ABS still plugged to the car if I forced the PC board with a screw driver it would work for a few seconds.
    Could someone give me a hint please?
    Attachment 365310Attachment 365311
  11. #248
    Dec 2019
    Hi All,
    My repair has worked. IC 9369.1D was replaced and 5df5 internal fault has disappeared. Very happy��
  12. The Following 8 Users Say Thank You to Sudnut For This Useful Post:
    boujou (10th March, 2021), BusCan (29th December, 2021), byyoyo (8th September, 2020), clauberty (15th March, 2024), line44 (30th March, 2021), mexanico1971 (16th March, 2020), mitch2 (26th March, 2020), tomvleeuwen (19th January, 2020)
  13. #249
    ThiagoArgentino's Avatar
    May 2016
    Brazil
    Has anyone caught a C26F5 defect in the SBC of a Mercedes SL 63 year 2010?
    Solutions in the area of automotive coded keys, all automakers.
  14. #250
    PT
    Hi to all, have a volvo v60 hybrid with problems on ABS unit, Think is an ATE MK26 unit has already been changed but problem persists.
    Always get brake pressure sensor error.
    Brake sensor on brake pump has already been replaced.
    When replacing unit i copied m95160, but even with recalibration problem persists.
    Anyone got virgin dump or know hot to solve this brake pressor thing??
    IMG_20190911_171700.jpgIMG_20190911_171716.jpgIMG_20190927_121406.jpgIMG-20200205-WA0001.jpg
    Carteknik
  15. #251
    PT
    I think this units are very similar to some found on Mercedes w204 and others.
    Anyone got any info? Pinout or how to connect on desk?
    Enviado do meu PCT-L29 através do Tapatalk
  16. #252
    Mar 2020
    Quote Originally Posted by soxten View Post
    Resolder both mcu and all pin on left side
    please tell me.... resolder the 2 mcus with hot air or with soledr iron?
  17. #253
    May 2016
    Brazil
    Hello
    I have a Mercedes C63, W207, internal ABS failure. Can you fix this?
    Scanner errors:
    - 5001
    - 5944
  18. #254
    Sep 2018
    I've got question about 1k0907379ad (VAG), about 16352 problem etc. If I want solve new 0990, I need to read by programmer old one? Thanks for help.
  19. #255
    Jul 2016
    Vilnius
    379AD is the shittiest module which isn't worth the time and effort spent towards it at all. Really.
    * MK100
  20. The Following User Says Thank You to hid3 For This Useful Post:
    luis12 (28th October, 2020)
