Page 4 of 21 FirstFirst 12345678914 ... LastLast
Results 46 to 60 of 303
  1. #46
    Aug 2011
    I will post it tomorow ... I will try again to clean it with new fluid heated to 60?C. For now I try fluid for carburetor, oxides, universal and always heated to 60?C. With all three fluids the abs block was in ultrasonic machine for more than 1h. I don't know wat is the new fluid I asked local seler and explain him the problem so he provide me this. I will report
  2. #47
    soxten's Avatar
    Mar 2013
    Please test!
    And if not work please take a way sensor and look inside the tube and see if it is clean.
    Christian Johansson via Iphone 5s
  3. #48
    DK Veteran thomas76's Avatar
    Oct 2010
    AC TRONIC repair MK60 with this solution :
    ABS ECU BMW 1 Series AND 3 Series ATE MK 60 Hydraulic Rebuild 2 Years Warranty | eBay
    The ABS hydraulic unit breaks down due to a failure of the internal brake pressure sensor. Many of our competitors will resolve this problem by assembling a pressure sensor on the outside of the unit. However, at ACtronics, we have developed a quality repair solution for the faulty, internal sensor, using our most advanced machinery.
    I think just one solution : REMPLACE SENSOR
    Electronic Automobile
    If post usefull press
    "THANKS"
  4. #49
    soxten's Avatar
    Mar 2013
    Ok, but how do they take a way the sensor w/o doing any marks on alu.block?
    The sensor is a hell to take a way!!!
  5. #50
    Oct 2011
    Can somebody help?I have problem with audi a3 2006 year,i think is mark 60
    DTC 01276
    ABS pump
    Circuit malfunction permanent
  6. #51
    soxten's Avatar
    Mar 2013
    Does all fix`d abs alu.block came with the "green" new Pressure sensor?
    Manpower for MID: LPKF Ups its Force - LPKF Laser & Electronics AG
    If you look at the top this is green and the old is black. (lock in the hole where the 4 connection plates are)
    Do some one have piture on a renoveted/fix`d Alu.block?
  7. #52
    Jan 2011
    C1380 abs pump blocked any one know a solution for this one from 206
    Sent from my GT-I9505 using Tapatalk
  8. #53
    soxten's Avatar
    Mar 2013
    Please piture on abs unit!
    Quote Originally Posted by insomnia2009 View Post
  9. #54
    soxten's Avatar
    Mar 2013
    New brake pressure sensor has 4 connections....
    a older brake pressure sensor has 3 connections ground(-), Plus (+) and 0-5V depending on pressure.
    Do someone have connections/wiring for this new sensor with 4 connections?
    http://www.bimmerfest.com/forums/sho...d.php?t=592136
    And here is a fix`d unit and it has GREEN sensor, not black as original.
    http://www.sercap.fi/product/34/ate-...nturin-korjaus
  10. The Following User Says Thank You to soxten For This Useful Post:
    mexanico1971 (20th November, 2014)
  11. #55
    mexanico1971's Avatar
    portugal
    HI !
    I have this ABS bosh to try to fix but there are a lot of wires broken on the side of the PCB and some in side of the plug connector !
    How can I take the silicon out , or what is the best solution to fix this
    thank"s in advance
    BR
    My work is my life ART TECH GARAGE
  12. #56
    smayer's Avatar
    Jan 2012
    Quote Originally Posted by mexanico1971 View Post
    HI !
    thank"s in advance
    BR
    Solution is remove gel with tweezers and solder new wires.
    I have had a bad experience with Fly ....
  13. The Following User Says Thank You to smayer For This Useful Post:
    mexanico1971 (21st October, 2016)
  14. #57
    soxten's Avatar
    Mar 2013
    Use microscope, remove gel over connectors by a pincet or small tool, only remove over the broken alu.wire!
    I always take away alu.wire from connector plate on pcb and unit.
    Use a small knife and "scrach" on connector plates and then put some solder material on the plate.
    Use 260-300 degres on solderstation.
    Use normal coper wire to replace alu.wire.
  15. The Following 3 Users Say Thank You to soxten For This Useful Post:
    bawareca (14th January, 2017), mexanico1971 (20th November, 2014), PierreTheron (9th February, 2016)
  16. #58
    soxten's Avatar
    Mar 2013
    Do not tuch/move the golden angel hair!!!!!!!
  17. The Following 3 Users Say Thank You to soxten For This Useful Post:
    h0ly (19th July, 2016), mexanico1971 (20th November, 2014), PierreTheron (11th March, 2016)
  18. #59
    soxten's Avatar
    Mar 2013
    ATE MK 25 unit
    Volvo V70 2005->>
    Solder all pin to pcb and use hot air to resolder all component on pcb.
  19. The Following 2 Users Say Thank You to soxten For This Useful Post:
    ivica21 (6th January, 2016), mexanico1971 (21st November, 2014)
  20. #60
    soxten's Avatar
    Mar 2013
    ATE MK 25 unit
    Volvo V70 2005->>
  21. The Following 2 Users Say Thank You to soxten For This Useful Post:
    mexanico1971 (14th September, 2016), Stelaras (24th November, 2017)
