Page 1 of 20 12345611 ... LastLast
Results 1 to 15 of 303
Hybrid View
    soxten's Avatar
    Mar 2013
    Default How to repair ABS system and units thread (repair,help,questions)
    Under this thread we talk about how to repair ABS system and units.
    ABS unit is often get broken and sometimes it is easy to repair.
    If we all share info about how to repair this units, all members on DK can get help.
    Please put our info and questions in this thread and if the thread is becomes big we my have a new master thread under Garage as "ABS system"
  2. The Following 8 Users Say Thank You to soxten For This Useful Post:
    borshch (1st January, 2018), DAVID8HENRY8 (8th May, 2016), engvitinho (20th May, 2023), lobofelix (3rd April, 2023), mexanico1971 (21st October, 2016), PierreTheron (11th March, 2016), shadab (25th November, 2014), Stelaras (24th November, 2017)
  3. #2
    soxten's Avatar
    Mar 2013
    Her is a thread of how to repair ABS unit to a Rover.
    Fault is that ABS pump engine is constant runing.
    The mosfet transistor was broken, see pictures in thread.
    http://www.digital-kaos.co.uk/forums...r-75-a-422432/
  4. The Following 6 Users Say Thank You to soxten For This Useful Post:
    carteknik (8th July, 2020), gameiruz (5th October, 2016), jmac200t (25th November, 2018), mexanico1971 (5th November, 2014), MV auto (11th March, 2016), PierreTheron (11th March, 2016)
  5. #3
    Jun 2016
    For soxtein
    hello i have identical problem with nissan qashqai. the ABS pump engine is constant runing.
    the link gives me " 404 file not found "
    you can post it again or put a picture please
    thank you
  6. #4
    Oct 2015
    Quote Originally Posted by giova71 View Post
    For soxtein
    thank you
    Anyone have info about how to repair this?
  7. #5
    Aug 2014
    Did you fix your qashqai abs, i also have same one running all the time?
  8. #6
    Sep 2019
    Hello, I have a problem with my Subaru Outback MY2010 ABS/ESP-unit. Only today, I found this thread, but I started an own thread here:
    https://www.digital-kaos.co.uk/forums/showthread.php/839324-problem-with-EUDM-Subaru-MY-2010-ABS-ESP-how-to-reprogram-the-unit?p=3919986#post3919986
    Please would you be so kind to take a look there? Thanks, Guy
  9. #7
    Sep 2019
    Is there anyone who could help me please, or direct me towards someone or somewhere else? Thanks
    Quote Originally Posted by guyc View Post
  10. #8
    tvzmaj's Avatar
    Jun 2010
    Serbia
    Quote Originally Posted by soxten View Post
    Edit link on this post. New link is http://www.digital-kaos.co.uk/forums...h-rover-75-a-/
  11. The Following User Says Thank You to tvzmaj For This Useful Post:
    alclot (6th June, 2018)
  12. #9
    soxten's Avatar
    Mar 2013
    Here is how to Repair Vw ABS units when you don`t get any comunications (it`s totaly dead)
    http://www.lbak.dk/Audi/Repair_ABS_unit_passat.pdf
    When you do this repair use microscop and small tools so you don`t brake any "angel hair" as is made of thin thin gold.
  13. The Following 26 Users Say Thank You to soxten For This Useful Post:
    antwnhszr (4th January, 2019), barsoom (26th April, 2019), BlacksunLE (7th April, 2017), borshch (8th April, 2017), buga37 (2nd August, 2016), cklair (9th October, 2014), Donabe (19th May, 2018), elecautocr (31st July, 2014), foxibg (1st March, 2016), gameiruz (5th October, 2016), Hayssam1 (12th August, 2015), ista74 (25th February, 2016), ivica21 (6th January, 2016), martinracing (10th November, 2014), martinsixto47 (7th July, 2021), mexanico1971 (25th September, 2014), mohamedkey (12th July, 2015), monir1999 (17th August, 2023), MV auto (11th March, 2016), nedved59 (28th February, 2016), nick_f (19th April, 2018), pezao (19th March, 2015), salimscan (20th April, 2018), shirokov (23rd October, 2014), Timppasa (9th October, 2014), tu329 (5th March, 2015)
  14. #10
    Oct 2015
    gaborone botswana
    great thnx mate
  15. #11
    soxten's Avatar
    Mar 2013
    BMW 730 E38 ABS unit with fault that abs pump is running all the time
    http://www.digital-kaos.co.uk/forums...-motor-386926/
  16. The Following 4 Users Say Thank You to soxten For This Useful Post:
    Bkjauto2010 (4th June, 2016), carteknik (8th July, 2020), mexanico1971 (5th November, 2014), PierreTheron (11th March, 2016)
  17. #12
    soxten's Avatar
    Mar 2013
    On Volvo S/V70 97-00 it often get fault as
    "ABS sensor left broken"
    "Flashing ABS light in dash"
    "No communications"
    And this is bad solder, so remove abs unit and open it up.
    resolder all bigger solder points on pcb and it start to work agin.
  18. The Following 4 Users Say Thank You to soxten For This Useful Post:
    carteknik (8th July, 2020), line44 (28th September, 2017), mexanico1971 (9th October, 2014), PierreTheron (9th February, 2016)
  19. #13
    soxten's Avatar
    Mar 2013
    Here is Vw Polo 02-05 ABS 6Q0907379E thread.
    http://www.digital-kaos.co.uk/forums...w-polo-302756/
    If someone has the password protected file from this thread please share without password.
  20. The Following 2 Users Say Thank You to soxten For This Useful Post:
    carteknik (8th July, 2020), PierreTheron (9th February, 2016)
  21. #14
    mexanico1971's Avatar
    portugal
    any one have some info about the repair of this ABS
    The link is dead
    Thank"s in advance
    My work is my life ART TECH GARAGE
  22. #15
    soxten's Avatar
    Mar 2013
    Help!
    On Vw Golf V it is usual that abs system fault "G201 presure sensor 01435" is broken.
    This is from a Golf 1,6 2008 with pressure tire controll
    Complete unit is 1K0614517AF
    OEM Vw i selling a reparations kit as named 1K698517B for 340 euro.
    Do any know how to repair this presure sensor?
    ABS unit is called ATE/Teves Mk60
  23. The Following User Says Thank You to soxten For This Useful Post:
