I have the problem of pressure sensor, can you tell me how to fix it ??? Thank you
Hello guys,
I have one MK26 Chrysler voyager 2007 with no communication.
What can be the problem ?
Regards,
What should i do on a abs pump laguna2 df185 error
Need help how to fix 4F0910517K with pressure sensor fault.
And this type is Bosch ABS 8.0 system and have a plastic brake pressure sensor on alu.block (not metall pressure sensor as the normal fault G201)
Fult is 01435 Brake pressure sensor 1 Activ.
need help how to find a way to repair this ecu.
Whats the best way to solder aluwires on BMW DSC ecu? And anyone got solution how to replace those golden ones?
Can you recommend any particular flush?
peugeot 207 abs ı check power 12 v ok gnd ok acc ok can ok but no communication
ı try difrent abs module communication ok
ı try resolder big pın problem same ı uplated pictures how is repair
Hello I have here a Mk25 volvo abs 2002
I need to connect it on bench.
Can somebody help me ?
8671224
Do i need to connect CEM also because if i use can wires now directly to obd from scan tool No COMM.
Dear Member of digital Kaos,
I spent 2 years months working on the subject.
I searched the pressure sensor...
I have sent on ACTRONICS my ABS ATE MK60 with an error of pressure sensor.
See the picture
the steel tube is cut.
Sorry for my english
Rollaass (22nd August, 2022)
the pressure sensor is repaired or change?
Here is info to ALL how to take away metall cover on Pressure sensor.
After you done this all 4 wire is lose on upper pcb under the gel.
If you solder it back on pcb you get problem after!
It is not working 100%
If some one find a way to solder it back, PLEASE SHARE!
First remove label on pressure sensor!
I put my tool in sideway to sideway in small movements, left to right and here the "click"
Then take tool away!
Take a small screwdriver and push black connector THEN lift steel tube up!
Importen! Push black connector down then lift steel tube!!!!!
Then open up the sensor by lift 2 small steel plate on side.
Next way is to find a safe way to repair it.
Normaly use wirebonding after cleaning gel out.
Please push tanks if it help you
Skickat från min iPhone med Tapatalk
boujou (10th March, 2021), DSAuto (15th October, 2018), dsz (12th September, 2018), Eddie034 (3rd December, 2017), evisdaci (25th September, 2023), g5n14 (23rd May, 2019), kelpe (18th December, 2020), kwat (13th January, 2024), makaronar (17th January, 2018), mexanico1971 (18th April, 2018), oiknikos (4th March, 2020), papyrusse (24th November, 2017), rochinha75 (3rd March, 2021), SvenR1 (13th March, 2018), TeiS (8th December, 2022), vertyk (11th July, 2023)
Thanks for your post soxten.
What's your tool?
Please, give me a link on google
the pressure sensor is a brand "BOSCH"?
