mexanico1971 (18th April, 2018), Rollaass (22nd August, 2022)
Correct that sensor is a newer model
Skickat från min iPhone med Tapatalk
this pressure sensor is very similar
Where are you from Soxten?
I am from France
Same as your picture as before.
This is a newer modell
It's toot difficult to clean.
I think it should be change
Do you have a bonding machine?
F&K Delvotec is very expensive
Anybody know where to get a 95042U3 chip from, looking at STs website its a discontinued product. What can replace it ? cant find the datasheet anywhere.
You cant change sensor.
If tou try to take it away you destroy the hole in alu.block.
You need to repair it by opening sensor up and then repair broken alu wire.
Faraday (30th March, 2020)
Hello everyone
I read this thread completely
Many customers find me and ask me this sensor
Recently
I have already asked my friend
If he finds 2PCS new sensor, original, working
He will send it to me
I study it, and then make it
If later, on this sensor, do not understand where I ask you, I hope you give me some help
Because I found a lot of people are very familiar with ABS ATE MK60 sensors, and have a wealth of experience
Sorry, I'm bad English
soxten (19th December, 2017)
Hello,
I have Mazda 3 with ABS error C0020.
Alredy checked power supply and ground to ECU. All ok.
In this car sometimes ABS light is OFF and ABS works correctly. Other times ABS is on with error C0020 and ABS don´t work.
Should I solder all components on the pcb ? Or its other problem ?
Check the photos:
Thanks for your help !
Solder all pin on left side
Solder all pin on mcu
Use hot air to resolder all other component on pcb, but dont heat components with plastic on!
aqua_life (26th December, 2017), mexanico1971 (18th April, 2018)
Thanks for your help.
When you say to solder left pins, should I solder the connectors pins that goes to pcb ?
From factory these are not soldered.
need help to repair 2004 Chevrolet Impala ABS Module.
"Service Traction System" comes up, and ABS and Traction lights come up
