Page 2 of 32 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 475
  1. #16
    Hello nero
    your coding ABS is:
    200200E3006F00B8042900EB00D900000000
  2. #17
    I thank but
    coding rejected
    error 78
    whether he needs to log on ?
    20795 not work
    SUGGESTIONS
    thenks
    Oh and by the way if my post has been at all helpfull it will encourage me to respond to posts if you remember to please press the little red Button
  3. #18
    Sep 2010
    Default long code esp polo
    hello I Can please help me
    ESP 8.2 6R0 907 379 AF
    VW POLO
    WVWZZZ6RZAY282406
    THANSK
  4. #19
    Dec 2015
    Birmingham, UK
    I SINCERELY hope somebody can help me. I need the ABS code for my car. When doing auto-scan with VAGCOM (VCDS) it shows as ABS Brakes - Not Registered. I have a VW Polo 6R 1.2 TDI Diesel 2012 (61 Plate) registered 31-12-15. Vin Number is WVWZZZ6RZCU015153
  5. #20
    bearheroes's Avatar
    Dec 2011
    Default VW Polo 6R 2012 Abs/Esp Coding 6R0 907 379 BC
    Can anyone help me with long coding?
    After all keys lost situation, abs has ciding 00000000...
    Vin WVWZZZ6RZBY183473
    ImageUploadedByTapatalk1449613060.119897.jpgImageUploadedByTapatalk1449613075.909252.jpg
    Thank you very much.
    Professional BMW immo solutions
    Macedonia is one and GREEK!!!
  6. #21
    bear, do you have old coding? What VIN is in new cluster?
  7. The Following User Says Thank You to 1 6 D For This Useful Post:
    bearheroes (9th December, 2015)
  8. #22
    bearheroes's Avatar
    Dec 2011
    cluster has the vin i wrote....i don't have old coding...forgot to read it before program keys...didn't change dash...just put it in service mode and program keys.
  9. #23
    habib, if there is Not registered, probably it's not coded in Installation list in CAN gateway
  10. #24
    Jul 2011
    France
    please help me
    audi S1 2.0 TFSI CWZ
    long coding abs
    esp 9.0i
    6c0907379j
    WAUZZZ8X3FB004802
  11. #25
    Dec 2015
    Birmingham, UK
    Quote Originally Posted by 1 6 D View Post
    i went into the installation list and it was off. Once I turned it on, tried the coding belouadi gave me and it did not work. It rejected it. I tried a few other codes from matching cars, but it still didnt work.
    So now im thinking, it might be the actual module is messed up. So I might get a replacement, but i dont want it to reject the code on the new module.
    Would anyone know where the module is and how i can replace it?
  12. #26
    Jul 2014
    Hi Guys,
    My pal try'd to change his instruments and now the abs lost the long coding.
    Can someone generate the coding for me?
    Its a Polo 6r0 907 379 AK
    wvwzzz6rzby335532
    Thanks!
  13. #27
    Abdo Abdelatif's Avatar
    Aug 2013
    kierownikszatni
    merci bien
  14. #28
    Hy mate can you calculate me long coding :
    The car is Touran 1T1 LHD 1.6 CAYC WVGZZZ1TZCW041603 MK60EC1 with ....BJ ESP unit
  15. #29
    wembleyhill's Avatar
    Feb 2009
    Hi all need coding for Audi A3 vin WAUZZZ8PXDAO19154 MK60EC1 1K0 907 379 BL used long code calculator v2.1 to generate code. code excepted but getting incorrect coding dtc
    code used is 13424012092400FFC80B02ED901D0081050000
  16. #30
    wembley, do you have start/stop?
