Can anyone please calculate for Polo 6R 5 door WVWZZZ6RZAY016568,
abs 8.2 6R0 907 379 AG
LHD, 1.6tdi CAYA engine
Hi Can someone please help me
Skoda Fabia VRS 1.4 TSI
Vin: TMBFP65JXB3188506
Abs: 8.2i FRONT H05 0003
part: 6R0 907 379 AA
HW: 6R0 907 379 AF
i have the autoscanif needed...
Hi all,
First of all: I think you are doing a GREAT, GREAT service here to everyone maintaining their cars!
I as well need the long code for a VW Polo:
SW: 6R0907379AE + HW: 6R0907379AC
VIN: WVWZZZ6RZAY203922
I truly believe in keeping cars on the road for as long as possible, since production of new cars is such a big polluter.
So, when our ABS module failed and VW quoted us 2000€+ to replace it, we were chocked!
I prefer 2nd hand spare parts; found a replacement-module online (with exactly the same codes), now I just need the long code.
Could you please help me out here?
Thanks in Advance,
Timo
HI need long coding
Part No SW: 1S0 614 117 S HW: 1S0 614 117 S
Component: EBC 460 ABS H03 0212
Can someone explain me what kind of software should I use to generate code (long coding) for abs module? because coding is: 000000000000000000000000000000000000.
VW GOL TREND 2015
tks in advance
Brolk...
Press "THANKS" button.
[QUOTE = Brolk; 3617572] Necesito una codificación larga
Parte NO SW: 1S0 614 117 S HW: 1S0 614 117 S
Componente: EBC 460 ABS H03 0212
¿Puede alguien explicarme qué tipo de software debo usar para generar código (codificación larga)? para el modulo abs? porque la codificación es: 000000000000000000000000000000000000.
VW GOL TREND 2015 tks por
adelantado
Brolk ... [/ QUOTE]
SOLVED......
I want to know there is any way to get long coding that is not online???
Brolk...
Diezmotorsport (25th February, 2020)
Did it before but using Odis online
wbr.
* MK100;
Brolk (13th July, 2019)
message for hid3.....if you are so bad with the guy ho not give you money in this site,you are the bad actor herre....,just for the reason that he not give you money beer....maybe i m not be able to pay you...in that moment.....not fairplay from you my' friend
hi guys, can anybody help to generate long code for ABS mk100 audi a3 8v, vin :WAUTPBFF7GA105667
ESC 5q090379AK
hy guys,i need codingabs module on skodasuperb 2012 year..... with vin number TMBAJ73T3C9008027...
with abs module 1K0 907 379 BH
ESP MK60EC1 H31 0121
IMP 790
WSC 33361
GERAET 00101....please need realy help...thanks
HELLO , i ihave an ibibza 2008 1.4 cayb i need long coding , HR: 6r0 907 379 AB ABS 8.2 FRONT H03 0001
vin: VSSZZZ6JZAR014555
Help To get Help!
MERCEDES-BENZ fan
Hello
I need long code for my 2011 Audi A1
I've tried several code without success...
6R0 907 379 BB
HW: 6R0 907 379 AH
1.4 Petrol CAXA
LHD
FWD, manuAl transmission
256mm/232mm brake
ESP off button : YES
Start/stop : YES
TPMS : NO
Hill-hold : NO
VIN : WAUAYA8X3BB091211
Can someone help me?
VIN: WAUAYA8X3BB091211 License Plate:
Chassis Type: 8X (8X0)
Scan: 01 03 05 08 09 14 15 16 17 19 25 42 44 46 47 52 5F
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: Sporadic communication error 1000
05-Acc/Start Auth. -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
14-Susp. Elect. -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Cannot be reached 1100
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAXA) Labels: 03C-906-016-CAX2.clb
Part No SW: 03C 906 016 BG HW: 03C 906 016 BG
Component: 1.4l R4/4V TS H08 8929
Revision: LEH08--- Serial number:
Coding: 00190012002401000000
Shop #: WSC 00046 790 12345
ASAM Dataset: EV_ECM14TFS01103C906016BG 001006
ROD: EV_ECM14TFS01103C906016BG.rod
VCID: 65C1571F64941D36075-8030
1 Fault Found:
4481 - Cruise Control Switch (E45)
P0568 00 [039] - Implausible Signal
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 92189 km
Date: 2019.07.22
Time: 00:21:47
Readiness: 1110 0101
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BB HW: 6R0 907 379 AH
Component: ESP8.2i front H07 0001
Revision: --------
Coding: 000000000000000000000000000000000000
Shop #: WSC 00046 123 12345
VCID: 7F0DE577EA08A7E6ED9-802A
2 Faults Found:
03306 - Coding Not Valid
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 102
Mileage: 92189 km
Time Indication: 0
Date: 2019.07.22
Time: 00:21:29
Freeze Frame:
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x3209
Hex Value: 0x14BD
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x7F00
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 102
Mileage: 92189 km
Time Indication: 0
Date: 2019.07.22
Time: 00:21:29
Freeze Frame:
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x3211
Hex Value: 0x14BD
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x7F00
Address 05: Acc/Start Auth.
Cannot be reached
Address 08: Auto HVAC Labels: None
Part No SW: 8X0 820 045 A HW: 8X0 820 045 A
Component: J255 Klima Manuell 0140
Revision: 0000707S Serial number: 03030004407744
Shop #: WSC 00046 000 00000
VCID: 3467FA5B57CEB4BE40B-8061
No fault code found.
Address 09: Cent. Elect. (J519) Labels: 8X0-907-063.clb
Part No SW: 8X0 907 063 D HW: 8X0 907 063 D
Component: BCM PQ35 M 108 0621
Revision: 00108 AC
Coding: 06000A3CA013F700605A41E020008946530B6F0A11AFC922DC 08879B0045
VCID: 3D71DF7FA48475F6BF5-8068
Subsystem 2 - Part No: 8X0 951 177
Component: DWA-Sensor H0 H01 0010
Subsystem 3 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
8 Faults Found:
00778 - Steering Angle Sensor (G85)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 141
Mileage: 92173 km
Time Indication: 0
Date: 2019.07.22
Time: 01:18:38
Freeze Frame:
Term 15 On
Voltage: 11.80 V
ON
ON
Term 50 On
OFF
OFF
01520 - Rain and Light Recognition Sensor (G397)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 211
Reset counter: 102
Mileage: 92173 km
Time Indication: 0
Date: 2019.07.22
Time: 01:18:38
Freeze Frame:
Term 15 On
Voltage: 11.80 V
ON
ON
Term 50 On
OFF
OFF
01504 - Bulb for License-Plate Light (X)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 39
Reset counter: 102
Mileage: 92173 km
Time Indication: 0
Date: 2019.07.22
Time: 01:18:40
Freeze Frame:
Term 15 On
Voltage: 11.75 V
ON
ON
Term 50 On
OFF
OFF
03351 - Bulb for DRL and Marker Light; Left
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 1
Fault Frequency: 38
Reset counter: 102
Mileage: 92173 km
Time Indication: 0
Date: 2019.07.22
Time: 01:43:29
Freeze Frame:
Term 15 On
Voltage: 11.70 V
ON
ON
Term 50 On
OFF
OFF
03354 - Bulb for DRL and Marker Light; Right
Freeze Frame:
Fault Priority: 1
Fault Frequency: 38
Reset counter: 102
Mileage: 92173 km
Time Indication: 0
Date: 2019.07.22
Time: 01:43:29
Freeze Frame:
Term 15 On
Voltage: 11.70 V
ON
ON
Term 50 On
OFF
OFF
02661 - Wire for Speed Signal
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 100
Mileage: 92173 km
Time Indication: 0
Date: 2019.07.22
Time: 00:44:41
Freeze Frame:
Term 15 On
Voltage: 14.60 V
ON
ON
Term 50 On
OFF
OFF
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 6
Fault Frequency: 1
Reset counter: 141
Time Indication: 0
Date: 2019.07.22
Time: 00:00:00
Freeze Frame:
Term 15 Off
Voltage: 12.15 V
OFF
ON
Term 50 Off
OFF
OFF
00447 - Function Limitation due to Over-Voltage
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 141
Mileage: 92174 km
Time Indication: 0
Date: 2019.07.22
Time: 00:18:45
Freeze Frame:
Term 15 On
Voltage: 15.00 V
ON
ON
Term 50 On
OFF
OFF
Address 14: Susp. Elect.
Cannot be reached
Address 15: Airbags (J234) Labels: 8X0-959-655.clb
Part No SW: 8X0 959 655 A HW: 8X0 959 655 A
Component: Airbag10.41 H04 0008
Revision: -------- Serial number: 003JJ001RVDR
Coding: 30314539303330303031554A304C38583053
ASAM Dataset: EV_Airba1041BPAAU210 001015
ROD: EV_Airba1041BPAAU210.rod
VCID: 489FBEABF346205E1C3-801D
Crash sensor for side airbag; driver side:
Serial number: 3554VRB40590BEE86GQR
Crash sensor for side airbag; passenger side:
Serial number: 3575HRB40690CE32C12B
Crash sensor for front airbag; driver side:
Serial number: 3585HRB405F0CE32CGOB
Rear Impact Crash Sensor:
Serial number: 3515ZRB40610D6ISF8GU
Address 16: Steering wheel (J527) Labels: 8X0-953-569.clb
Part No SW: 8X0 953 501 HW: 5K0 953 569 F
Component: LENKS.MODUL 014 0140
Revision: FF010016 Serial number: 20110329201675
Coding: 1180204000
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: F7FD8D574E381FA6259-80A2
Address 17: Instruments (J285) Labels: 8X0-920-xxx-17.clb
Part No SW: 8X0 920 900 HW: 8X0 920 900
Component: KOMBI H05 0124
Serial number: 00000000000000
Coding: 114200
ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04086
ROD: EV_Kombi_UDS_VDD_AU10.rod
VCID: F4E7BA5B5F4E74BE00B-80A1
Address 19: CAN Gateway (J533) Labels: 8X0-907-468.clb
Part No SW: 8X0 907 468 A HW: 8X0 907 468 A
Component: GAT 4CAN 1L M H04 0083
Revision: 1C060023 Serial number: 2341C113228054
Coding: FB0F0064000100010053
VCID: 4385A987C2600306C91-8016
Subsystem 1 - Part No SW: 8K0 915 181 H HW: 8K0 915 181 H
Component: J367-BDM H07 0171
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 141
Mileage: 92173 km
Time Indication: 0
Date: 2019.07.22
Time: 01:22:11
Freeze Frame:
Bin. Bits: 10111
Voltage: 11.60 V
Count: 6
Bin. Bits: 10011
Time: 25.40 s
00471 - Control Module for Elect. Regulated Dampers (J250)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 100
Mileage: 92173 km
Time Indication: 0
Date: 2019.07.22
Time: 01:22:11
Freeze Frame:
Bin. Bits: 10111
Voltage: 11.60 V
Count: 6
Bin. Bits: 10011
Time: 25.40 s
00456 - Control Module for Access and Start Control (J518)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 100
Mileage: 92173 km
Time Indication: 0
Date: 2019.07.22
Time: 01:22:12
Freeze Frame:
Bin. Bits: 10111
Voltage: 11.60 V
Count: 6
Bin. Bits: 10011
Time: 25.40 s
00463 - Control Module for Digital Sound Package (J525)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 100
Mileage: 92173 km
Time Indication: 0
Date: 2019.07.22
Time: 01:23:10
Freeze Frame:
Bin. Bits: 10000
Voltage: 11.70 V
Count: 10
Bin. Bits: 10010
00384 - Optical Databus
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 3
Reset counter: 102
Mileage: 92173 km
Time Indication: 0
Date: 2019.07.22
Time: 00:10:27
Freeze Frame:
Bin. Bits: 10111
Voltage: 11.60 V
Count: 6
Bin. Bits: 00010
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H05 0124
Serial number:
Coding: 000002
Shop #: WSC 00046 790 00000
ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04008
ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386) Labels: 8X0-959-793.clb
Part No SW: 8X0 959 793 D HW: 8X0 959 793 D
Component: TSG FA H09 0409
Revision: -------- Serial number: --------------
Coding: 011E02200100000100
VCID: 4E9388B31922FE6E56F-801B
1 Fault Found:
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 127
Mileage: 96625 km
Time Indication: 0
Date: 2019.07.17
Time: 00:07:29
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11251
Shop #: WSC 00046
VCID: 2F6DF537EAE897663D9-807A
Address 47: Sound System
Cannot be reached
Address 52: Door Elect, Pass. (J387) Labels: 8X0-959-792.clb
Part No SW: 8X0 959 792 D HW: 8X0 959 792 D
Component: TSG BF H09 0409
Coding: 011E02200D00000100
VCID: 4D918FBF1424C5762F5-8018
Address 5F: Information Electr.
Cannot be reached
End ---------------------------------------------------------------------
Last edited by mashunga; 14th August, 2019 at 09:52 PM. Reason: text color was wrong
seat ibiza
1.2 CGPA 2009
VSSZZZ6JZAR028115
ABS 8.2 H03 6R0907379AB
help long code
Hello
please I lost coding for seat ibiza 2012
VSSZZZ6JZCR081594
ABS 8.2 front 6R0 907 379 AD H03 0001
can I get help please ?
Please get me the abs long code for
Vw polo 1.2 tsi
Vin AAVZZZ6RZGU048219
ESP 9.0i h030004
Automatic petrol
6C0 907 379 K
