Page 1 of 31 12345611 ... LastLast
Results 1 to 15 of 479
Hybrid View
    kierownikszatni's Avatar
    Mar 2010
    Poland/Germany
    Default VW Polo 6R 2012 Abs/Esp Coding 6R0 907 379 BC
    Hi!
    Can someone explain me what kind of software should I use to generate code (long coding) for ESP module? I want to recode ABS/ESP module because coding is: 000000000000000000000000000000000000. (i've changed instrument cluster... )
    ESP 8.2i 6r0907379BC
    VW Polo 6R
    Thanks in advance.
    Jul 2010
    melbourne, australia
    AVDI has a coding helper which will give you codes, Ive not used it for abs but the stuff I ahve used it on worked pretty well, I also know VCDS in its later versions has coding advice
    Dec 2009
    Vag can pro can do it fine for MK60EC1 and ESP8.x
    It is payable option
    amrif's Avatar
    Dec 2009
    EU
    Quote Originally Posted by exe123 View Post
    like VCDS VCP don't generating correct coding but maybe their support will help.
  5. The Following User Says Thank You to amrif For This Useful Post:
    Dluisao (27th January, 2019)
  6. #5
    Post abs coding from similar model and your vin and i encode your vin into coding from another.
  7. The Following User Says Thank You to autofan1965 For This Useful Post:
    kierownikszatni (29th July, 2014)
  8. #6
    Mar 2010
    Poland/Germany
    Quote Originally Posted by autofan1965 View Post
    210228E3217300B8842E14EB84D200401300
    210228E3417100B2842A14EA82D600421700
    210224E3416D00BB842E24E782D300421500
    210228E3417100B2842A14EA82D600421300
    VIN: WVWZZZ6R*********
  9. The Following User Says Thank You to kierownikszatni For This Useful Post:
  10. #7
    your coding ABS is :
    210248E3416D02B2842612E482D240411700
  11. The Following 11 Users Say Thank You to belouadi For This Useful Post:
    achraf11 (23rd March, 2016), antonypaul (12th November, 2014), Audipete (29th November, 2018), CaioW (19th January, 2017), datapage (3rd June, 2016), dreamboxservice (5th January, 2018), elzaim (18th March, 2019), Fallen (8th September, 2014), kierownikszatni (31st July, 2014), samranisimo (29th January, 2017), tsanev (7th July, 2022)
  12. #8
    Mar 2010
    Poland/Germany
    Quote Originally Posted by belouadi View Post
    It works!!!!!! Thanks a lot!
  13. #9
    Oct 2016
    Hello can someone please help me too calculate the long coding of my polo:
    2010 1.6tdi Dsg
    Bosch abs 8.2i ESP
    Software: 6r0907379BE
    Hardware: 6r0907379AF
    Version: 0001
    Version: H05
    Wvwzzz6rzbu017083
    After we changed the cluster the long code disappeared, the original cluster has been stolen.
  14. #10
    Feb 2013
    namiba,zimbabwe
    can any one help me with coding for Abs on polo 6R just shows 0000000
    vin AAVZZZ6RZCU035725
    vag no 6r0907379aq
    abs9.0 front h01 0003
    The information I share is purely for research and educational purposes I can not be held responsible for any damage to devices or any injury caused by malfunctioning devices
  15. #11
    Sep 2015
    Default recode abs polo 6r
    I also need login coding for my car because i replaced instrument.
    ABS VAG NUMBER 6R0807379AF
    ESP8.2i front H05 0005
    VIN: WVWZZZ6RZAY108899
    THANKS
  16. #12
    Oct 2018
    Can you help me please I need ABS code for Seat Ibiza 1.2 tdi 2010 ecomotive style.
  17. #13
    Mar 2014
    Please help me with long coding for ABS 8.2 front
    Skoda Fabia 2012 CAYA
    6R0907379AB
    VIN: TMBES25J2C3132175
  18. #14
    Feb 2020
    Hello do you have de ESP/ABS (long) coding for a Seat ibiza VIN:VSSZZZ6JZBR191416 Vin is from the new dash
    I lost it by changing the dash
    Regards
  19. #15
    Dec 2009
    VCDS cannot do MK60EC1 where VIN is part of it.
    I'm using VCP since two years with MK60EC1. Works always and never let me down
