Hello!
I need help coding the ABS 8.2 for my car :
Skoda Fabia 2010r
1.2 TSI 63 kw CBZA
LHD
Start-Stop- no
TMPS - no
VIN. TMBEM25J9B3167689
Pomp. 6R0907379S
Thank you in advance
No need to swap the dashes again.
Try this coding, assuming the original dash is in place:
400100DB007000BB022A00E300D100000000
I can calculate ABS module codings for:
* Continental/Teves MK60EC1 and MK60;
* TRW systems in Passat B6 / B7 / CC /Tiguan;
* MK100;
* Bosch ABS8.2, ABS9.0 and ESP8.2, ESP9.0;
* EBC 460 (UP!, Mii, Rapid, CitiGo, Fabia, Toledo, etc) New!
* ... and other VW/Audi/Seat/Skoda modules.I can assist with repairing \/CDS interfaces.
Hello!
Skoda Fabia 2010r
1.2 TSI 63 kw CBZA
LHD
Start-Stop- no
TMPS - no
Pomp. 6R0907379S
try this for the Fabia:
400100DB007300B9022B00EA00DA00000000
* MK100;
orlik1 (21st October, 2017)
work perfect
thank you
Hello hid3!
Thank you very much for your help, encoding accepted . I checked it yesterday (as soon as I can)
Thank you! Regards!
Hi all..can any 1 assist with abs long coding....
6R0 614 517 AN
ABS esp 8.2i H05 0002
vin: WVWZZZ6RZCU060318
1.2 TSI CBZB Right Hand Drive
Thanks you very much!
Hello
need help long coding
Vw polo
ESP 8.2i front H04 0002
6R0 907 379R
WVWZZZ6RZAY194968
1.2 Petrol LHD TPMS
Hello
I need long code for my 2010 6R Polo Trendline
I've tried several code without success...
6R0 907 379 AJ
1.6 diesel CAYB
LHD
FWD, manuel transmission
256mm/232mm brake
ASR/ESP off button
No Start/stop
No TPMS
Hill-hold activated
WVWZZZ6RZBY124617
Can someone help me?
After lot of searching and analysing, i've found a code who worked!
210228E3416F00B6842B14E382D800421000
But the code is for automatic transmission, my polo got manual transmission...
Got a default "Code not valid" and not allowed to set ESP and steering wheel
Here the code I need but not allowed
210228E3216F00B6842B14E384D800421000
Where is the problem and how can i do to solve it?
Hi lost abs code on Fabia 2012 6r0907379s
hello
i have seat ibiza engine code BMS
Can anyone please calculte me corret coding
Monday,27,November,2017,05:14:36:29185
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.8.0.1 (x64) HEX-NET CB: 0.4401.4
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: VSSZZZ6JZAR058240 License Plate:
Chassis Type: 6J-SE25 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 4B 56
VIN: VSSZZZ6JZAR058240 Mileage: 126670km-78709miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine Labels: 045-906-013-BMS.clb
Part No SW: 045 906 013 AB HW: 045 906 013 AB
Component: R3 1,4L EDC 0000SG 3527
Revision: --H04--- Serial number:
Coding: 0053071
Shop #: WSC 06402 785 00200
VCID: 4FEEBEA4DEAF2D3E43-801A
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ABS82.clb
Part No SW: 6R0 907 379 AD HW: 6R0 907 379 AB
Component: ABS8.2 front H03 0001
Revision: --------
Coding: 000000000000000000000000000000000000
Shop #: WSC 00788 648 00255
VCID: 004C4D98977102468A-8054
1 Fault Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 4
Reset counter: 80
Mileage: 126660 km
Time Indication: 0
Date: 2012.04.19
Time: 13:56:53
Freeze Frame:
Hex Value: 0x0005
Hex Value: 0x0000
Hex Value: 0x3213
Hex Value: 0x1490
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7F00
Hex Value: 0x0000
Address 08: Auto HVAC Labels: 6J0-820-045.clb
Part No SW: 6J0 820 045 HW: 6J0 820 045
Component: J301 Klimaanlage 0280
Revision: 00 23 08 Serial number: 0000000209581-
Shop #: WSC 00000 000 00000
VCID: 63866214A227B95EF7-8036
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 B HW: 6R0 937 087 B
Component: PQ25 BCM H09 0025
Revision: BF009001 Serial number: 9955A246092311
Coding: 3C882BE888610100002000007E0B1CC80000420F608C000020 00
Shop #: WSC 64564 324 38760
VCID: 3C34F968BF19A6A696-8068
Subsystem 1 - Part No SW: 6R0 959 801 A HW: 6R0 959 801 A Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 001 0238
Serial number: --------------------
Coding: 020000
Subsystem 2 - Part No SW: 6R0 959 802 C HW: 6R0 959 802 C Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 001 0242
Coding: 020000
Address 10: Park/Steer Assist (J446) Labels:| 6J0-919-475.clb
Part No SW: 6J0 919 475 A HW: 6J0 919 475 A
Component: PARKHILFE 4K H07 0007
Revision: -------- Serial number: 80330924800029
Coding: 000002
ASAM Dataset: EV_SE250ParkiAssis2 S01006
ROD: EV_SE250ParkiAssis2.rod
VCID: 3424D1489F496EE65E-8060
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10AirbagA09 H09 0018
Revision: -------- Serial number: 003DW006AL76
Coding: 003039
Shop #: WSC 06401 785 00200
ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250_VW31.rod
VCID: 42C88790D5FDD056DC-8016
Crash sensor for side airbag: driver side:
Serial number: 3496GRB402F9NI6CPB6Z
Crash sensor for side airbag: front passenger side:
Serial number: 3506GRB402P9NI6D23EF
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 6J0 920 801 A HW: 6J0 920 801 A
Component: KOMBI H07 0110
Serial number: 00000000000000
Coding: 110200
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
VCID: 25023C0C2493076ED9-8070
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087 B
Component: GW-K-CAN TP20 0025
Coding: 022200
VCID: 70AC1D58A3D112C67A-8024
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H07 0110
Serial number:
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 A
Component: LenkhilfeTRW V275
Coding: 10111
Shop #: WSC 06402
VCID: 2E10C320ED65443628-807A
Address 4B: Multifunc. Module Labels: 6J0-959-441.clb
Part No: 6J0 959 441
Component: MF-Modul 0007 0001
Coding: 0000001
Shop #: WSC 77005 000 00000
VCID: 70AC1D5863D112C67A-8024
Address 56: Radio (J503) Labels:. 6J0-035-153.clb
Part No SW: 6J0 035 153 HW: 6J0 035 153
Component: Radio H11 0027
Revision: R0000000 Serial number: SEZAZ1I7268440
Coding: 0503040002
Shop #: WSC 04941 000 00000
VCID: 618A681C783BAB4EE5-8034
End----------(Elapsed Time: 01:06, VBatt start/end: 12.5V/12.5V)-----------
Hello
need help long coding abs esp
Seat ibiza 6J
ESP 8.2i front H05 0002
6R0 907 379 BC
VSSZZZ6JZDR009275
CAYB-1.6L TDI-CR 66KW EU5 DPF
