Page 1 of 32 12345611 ... LastLast
Results 1 to 15 of 475
    kierownikszatni's Avatar
    Poland/Germany
    Default VW Polo 6R 2012 Abs/Esp Coding 6R0 907 379 BC
    Hi!
    Can someone explain me what kind of software should I use to generate code (long coding) for ESP module? I want to recode ABS/ESP module because coding is: 000000000000000000000000000000000000. (i've changed instrument cluster... )
    ESP 8.2i 6r0907379BC
    VW Polo 6R
    Thanks in advance.
    melbourne, australia
    AVDI has a coding helper which will give you codes, Ive not used it for abs but the stuff I ahve used it on worked pretty well, I also know VCDS in its later versions has coding advice
    Vag can pro can do it fine for MK60EC1 and ESP8.x
    It is payable option
    Post abs coding from similar model and your vin and i encode your vin into coding from another.
  5. The Following User Says Thank You to autofan1965 For This Useful Post:
    kierownikszatni (29th July, 2014)
    amrif's Avatar
    EU
    Quote Originally Posted by exe123 View Post
    like VCDS VCP don't generating correct coding but maybe their support will help.
  7. The Following User Says Thank You to amrif For This Useful Post:
    Dluisao (27th January, 2019)
  8. #6
    VCDS cannot do MK60EC1 where VIN is part of it.
    I'm using VCP since two years with MK60EC1. Works always and never let me down
  9. #7
    Poland/Germany
    Quote Originally Posted by autofan1965 View Post
    210228E3217300B8842E14EB84D200401300
    210228E3417100B2842A14EA82D600421700
    210224E3416D00BB842E24E782D300421500
    210228E3417100B2842A14EA82D600421300
    VIN: WVWZZZ6R*********
  10. The Following User Says Thank You to kierownikszatni For This Useful Post:
  11. #8
    your coding ABS is :
    210248E3416D02B2842612E482D240411700
  12. The Following 11 Users Say Thank You to belouadi For This Useful Post:
    achraf11 (23rd March, 2016), antonypaul (12th November, 2014), Audipete (29th November, 2018), CaioW (19th January, 2017), datapage (3rd June, 2016), dreamboxservice (5th January, 2018), elzaim (18th March, 2019), Fallen (8th September, 2014), kierownikszatni (31st July, 2014), samranisimo (29th January, 2017), tsanev (7th July, 2022)
  13. #9
    Poland/Germany
    Quote Originally Posted by belouadi View Post
    It works!!!!!! Thanks a lot!
  14. #10
    Fallen's Avatar
    Can anybody work mine out for me too please.
    ESP 8.2i 6R0907379BC H05 0002
    VW Polo 6R
    WVWZZZ6R********
    Thanks guys.
  15. #11
    here
    can some one help me to recood this abs for caddy 2k ,mk70:
    http://www.digital-kaos.co.uk/forums...g-help-438673/
  16. #12
    Hello Fallen
    210248E3417202B7842712EA82D640411700
  17. The Following 2 Users Say Thank You to belouadi For This Useful Post:
    antonypaul (22nd February, 2016), Fallen (9th September, 2014)
  18. #13
    Sep 2011
    south africa
    Hi all..can any 1 assist wit abs long coding....
    6R0907379AD
    ABS 8.20 front h03 0001
    vin: AAVZZZ6RZBU028410
    i replaced lockset on car but cant code abs..and can i use original vcds?
  19. #14
    Jan 2011
    Hello I need long coding to ABS SEAT IBIZA ESP 8.2 6R0 907 379 AK
  20. #15
    hello I Can please help me
    ABS 8.2front 6R0 907 379 AD
    SEAT ibiza
    VSSZZZ6JZCR026498
    THANSK
    Oh and by the way if my post has been at all helpfull it will encourage me to respond to posts if you remember to please press the little red Button
  21. The Following User Says Thank You to __nero__ For This Useful Post:
    chiraze (19th February, 2016)
