Results 1 to 9 of 9
Thread: Q5 HD Setup
    Jun 2009
    Default Q5 HD Setup
    Just got a Q5 HD, tried to scan but never got all channels, not sure if scanning right anyone got a guide?
    Thx Steve
    Jul 2008
    Assume you got this sorted mate? If not post back. They normally come with latest firmware, load up a cables xml and should be a case of just scanning them in.
    If your still having a problem here is the manual.
    Aug 2014
    I have some channels but not all. What do I do to get all of them?
    Thank you in advance.
    Top Poster fazz69's Avatar
    Feb 2009
    Somewhere
    have u uploaded the cable.xml file to box
    Sep 2008
    I'm having the same problem..Not scanning in all the channels after doing a provider scan. I have added what I believe to be up to date cable.xml file?
    I'm based in the old TW uddingston region and missing quite a few channels including Sky Sorts5HD? Anyone confirm that I'm scanning properly.
    G
    DK Veteran lincsat's Avatar
    Jun 2008
    Do a NIT scan starting from a working frequency, do not use the default frequency setting.
  8. The Following User Says Thank You to lincsat For This Useful Post:
    rigsby71 (20th May, 2017)
    Sep 2008
    cheers for the reply lincsat.........I actually resolved it at about 3 am this morning when I found what I would say was a more in depth/detailed cable.xml file. It immediately loaded in all the channels.
  10. #9
    Mar 2009
    Warrington, Cheshire
    Quote Originally Posted by lincsat View Post
    it's an old thread , but I have just come across this old box & your suggestion of Nit search on working frequency has worked a treat, I have spent a good hour trying to scan & only getting a few here & there.
    So many thanks again.
