Results 1 to 15 of 24
    happy_highlander's Avatar
    Aug 2010
    Default Happy_Highlander E1 and E2 UK Channel lists
    Happy_Highlander
    E1 & E2
    UK Channel Lists
    These Lists match the layout of all my other lists and DO NOT match the sly uk layout
    Latest lists can be found Here
    E2 UK picon10-08-14
    E1 UK picon 10-08-14
  2. The Following 9 Users Say Thank You to happy_highlander For This Useful Post:
    archie 1 (21st August, 2014), Boost420 (8th November, 2014), digicon (11th August, 2014), dj1978 (14th August, 2014), DPDD (13th August, 2014), gmb45 (7th December, 2014), jimmynewbie (12th October, 2014), macbow (16th September, 2014), WOODWARD395 (9th October, 2014)
  3. #2
    Many thanks for this! I've got a slight issue with the bouqets in the sense on my box it shows 'removed servce' as the groups with no channels inside rather than 'movies, sport etc'. Can you please advise how i can fix this? Thank you in advance
    Aug 2010
    What box and what list have you used. You normally get that if you use the e2 type 4 settings in an e1 box e.g tm500, dm500 instead of the type 2 e1 list. I haven't got an e1 box atm to test the e1 list but they should work.
    Aug 2010
    New Lists and picons correct to 20-09-14
    E1_UK_picon_20-09-14.rar
    E2_picon_20-09-14.rar
  6. The Following User Says Thank You to happy_highlander For This Useful Post:
    May 2012
    Im a newbie on here with a technomate tm5402 which channel list do i download for the euro sats and sly uk?
  8. #6
    Aug 2010
    This one, kindly being kept updated by digicon http://www.digital-kaos.co.uk/forums....php?p=2386805
  9. #7
    Aug 2010
    Happy_Highlander
    E1 & E2
    UK Channel Lists
    E1 UK Picons E1_UK_picon_01-11-14.rar
    E2 UK Picons E2_UK_picon_01-11-14.rar
  10. The Following 2 Users Say Thank You to happy_highlander For This Useful Post:
    jimmynewbie (3rd December, 2014), Wingnut (29th November, 2014)
  11. #8
    DK Veteran loncell's Avatar
    Jun 2008
    Hi Highlander , do you do a full motor for E1 ?
  12. #9
    Aug 2010
    No m8. I don't have a motor or an e1 box anymore. Download or scan in an e2 list then you get any existing e1 motor list and open it in dbe then use the compare services tool to compare it to the up to date e2 list you can add and remove all the relevant sd channels from the e2 and save the modified e1 list. This will preserve the e1 structure but allow you to keep them updated. That's the way I do mine for uk
  13. #10
    Aug 2010
    Happy_Highlander
    E1 & E2
    UK Channel Lists
    E1_UK_picon_06-12-14.zip
    E2_UK_picon_06-12-14.zip
  14. The Following User Says Thank You to happy_highlander For This Useful Post:
    stualdo (23rd December, 2014)
  15. #11
    Thanks Happy Highlander,
    Have there been any recent updates for this list
  16. #12
    Aug 2010
    Not recently just been way to busy. When i get a chance I'll sorry something out.
  17. #13
    Thanks ill keep searching in the mean time.
  18. #14
    Aug 2010
    Happy_Highlander
    E1 & E2
    UK Channel Lists
    E1_UK_Picon_29-04-15.zip
    E2_UK_Picon_29-04-15.zip
  19. The Following 4 Users Say Thank You to happy_highlander For This Useful Post:
    chetsp (3rd May, 2015), digicon (2nd May, 2015), maca (2nd May, 2015), tim rob (29th May, 2015)
  20. #15
    Aug 2010
    Happy_Highlander
    E1 & E2
    UK Channel Lists
    E1_UK_Picon_03-07-15.rar
    E2_UK_Picon_03-07-15.rar
  21. The Following 9 Users Say Thank You to happy_highlander For This Useful Post:
    BlueBox (15th July, 2015), Boost420 (18th August, 2015), chetsp (11th July, 2015), digicon (6th July, 2015), DPDD (19th July, 2015), joe516 (5th July, 2015), jorvikwhite (6th July, 2015), maca (5th July, 2015), mufc2012 (11th July, 2015)
