Page 1 of 3 123 LastLast
Results 1 to 15 of 35
    iamfooser's Avatar
    Sep 2012
    Default Landrover Freelander Sawdoc Solution
    Hi guys,
    I have a Landrover Freelander that uses SAWDOC immobilizer. It is all lost siutation. Only solution that I have is the expensive TMPRO and AD900?
    Anyone know how to precode the transponder or a cheaper solution to this?
    Thank you.
    Regards,
    ps.It is not possible for me to buy key from dealer here
    aassfour's Avatar
    May 2013
    kensington
    get a dealer key and program it by OBD easy
    The only place success comes before work is in the dictionary.
  3. The Following 2 Users Say Thank You to aassfour For This Useful Post:
    electromech (7th April, 2015), iamfooser (12th August, 2014)
    iamfooser's Avatar
    Sep 2012
    Quote Originally Posted by aassfour View Post
    The local dealer quoted me $900 for a dealer key and I have to wait for at least a month.
    aassfour's Avatar
    May 2013
    kensington
    ur dealer is high
  6. The Following User Says Thank You to aassfour For This Useful Post:
    Fallen (12th August, 2014)
    WW
    change sawdoc with ews, is easy to read and edit, and put paired dump ecu+ews, make transponder , i have some paired dumps, depend your engine ecu
  8. The Following 13 Users Say Thank You to elephantul For This Useful Post:
    autoTkey (8th October, 2019), BusCan (30th September, 2015), Fallen (12th August, 2014), gepakg (10th September, 2014), gwee (12th August, 2014), iamfooser (13th August, 2014), instakeys (10th April, 2015), Meat-Head (17th August, 2014), mickye_dj (25th December, 2022), obdsystems (7th April, 2015), shanektm450 (26th May, 2016), Siham (8th April, 2015), workdamnyou (13th August, 2014)
  9. #6
    gwee's Avatar
    Dec 2012
    unknown
    Quote Originally Posted by elephantul View Post
    cable connector same for sawdoc and ews?
  10. The Following 2 Users Say Thank You to gwee For This Useful Post:
    keyantic (12th April, 2015), LKEY (8th March, 2022)
  11. #7
    WW
    yes, same conector, i change myself in one freelander with sawdoc, car have desincronize ecu and sawdoc, cant succeed read sawdoc, even with tmpro, i buy only second hand ews (from freelander not bmw) is strange ews, inside like ews3, conector like ews2, i make transponder, read ecu dump and manual sync with ews (like bmw), car start without modifi conector or wires
  12. The Following 17 Users Say Thank You to elephantul For This Useful Post:
    clauberty (25th January, 2019), d.zio (8th March, 2015), datapage (16th July, 2015), Fallen (13th August, 2014), garzonaj (5th May, 2017), gepakg (10th September, 2014), gwee (12th August, 2014), iamfooser (13th August, 2014), igorr (13th August, 2014), instakeys (8th April, 2015), mickye_dj (25th December, 2022), milehighlockdoc (11th May, 2019), obdsystems (7th April, 2015), paul_12345 (12th August, 2014), SALAS (5th August, 2017), Siham (12th August, 2014), workdamnyou (13th August, 2014)
  13. #8
    gwee's Avatar
    Dec 2012
    unknown
    very good info mate
  14. The Following User Says Thank You to gwee For This Useful Post:
  15. #9
    iamfooser's Avatar
    Sep 2012
    Alright, I will let my customer know and will try to get ews for landrover if my customer agree with it. Thank you so much for the information.
    Sent from my HTC Desire 600 dual sim using Tapatalk
  16. #10
    iamfooser's Avatar
    Sep 2012
    Now owner found back the key but have P1602 - ECM/immo comm error. Is it possible for us to sync them manually?
    Car has
    sawdoc and
    DDE 0 281 010 811
    NNN500340
    Jlr could not communicate with this car as this car is made in 05.
    I am open any ideas and suggestions. Thank you in advance.
  17. #11
    WW
    if jlr not comunicate with car maybe have another trouble, for sync need engine eprom and sawdoc eprom
  18. #12
    iamfooser's Avatar
    Sep 2012
    Other diagnostic can communicate without problem. Apparently JLR can only support car with canbus and this car does not. Alright, I will read and post the eeprom next. Thanks.
  19. #13
    Jan 2013
    Hi I have landrover with dde ecu can you help me with a working set of dumps? i want to replace sawdoc with ews. thanks in advance
  20. #14
    Jun 2011
    devon uk
    Hi all
    quick question
    got sawdoc LR, all keys lost, key ordered form dealer obviosuly need coding.
    will mvp pro code the key to the car without a working one?
    according to AD IQ it doesn't require working key but form my research i think it does.
    car is bit far away and i dont want to waste my time to find out myself
    can anyone cofirm if MVP pro require working key to code a new key which is form main dealer?
    if mvp pro cant do it - is there any other tool which can?
    Thanks in advance
  21. #15
    iamfooser's Avatar
    Sep 2012
    If key is ordered from dealer, MVP pro should be able to do it. As key is precoded with the correct data. When I tried with MVP pro, I did not have pre coded transponder. Also I didnt manage to complete this job as owner found his key.
    But there was a problem as it lost sync between sawdoc module and ecu. It was finally fixed by dealer.
  22. The Following 2 Users Say Thank You to iamfooser For This Useful Post:
    robert81 (10th April, 2015), Siham (8th April, 2015)
