FVDI CANNOT PROGRAM A KEY
tried to program a vgs but stops n 9seconds n quits.
does someone have a guide of doing it apart from using the arbitres guide for 7g renew
more tests coming, when I remember!
can't rest battary sensor or even TPM for KM i ment
Does not play CD's either mate ..
dave11674 (31st August, 2015), ghostrider72 (4th November, 2018), mvtamele (30th August, 2015)
IT CAN!
On no, sorry I was thinking of my old Alba stereo I had when I was 10, because that did more things than FVDI!
Any clue , somebody try to virginize Mercedes W212 - 7G tronic gearbox ecu ?
I got a problem regarding - CAN BUS OFF - in gearbox ECU -
I have 3 options :
1. Buy new unit from mercedes dealer and program with Autologic mercedes software
2. Send the unit to be repaired ... ( i don't know if it will work )
3. Get a second hand unit - Virginise it with FVDI and do SCN online coding with Autologic...
Somebody can light me up with this one ? Regards . John
Dosen't matter how hard is to repair something as long is made by humans and thinked by humans !
alexbeshko (5th November, 2018)
Read the SCN string code from your old VGS and after you renewed your second hand VGS copy your old string code into the renewed one and finish job with das.
BTW check your PM.
W211 2004 DASH KM CHANGE IN IC VIA OBD WORK OKEY AND BLOCK SYNCH WITH EZS FVDI V6.4 BUT V5.11 NOT WORK
hamzadaw2000 (22nd June, 2015)
garabounga said:
Today~02:02 PM
hallo guys
maybe i have a good feedback for fvdi users as i had een issue with sync ews dde this morning i wanted to remove dde as i thoud i wil never work before that i wanted to try one more time went special functions sync ews dde push button nothing happend keept saying sync not possible i tryed like four times the fifth time it says sunc sucsesful and the car started some users reported that this function dont work geuss what it does you just have to repeat it and it wil work i khnow it was no wonder as they are no wonders in electronics
i hope this feedback is useful
I removed my reply from ecu forum and put it hier i geuss its more usefull hier
Oh ja its regarding bmw x 5 2003 3.0 diesel
Fvdi not work for a-class w168 transponder
It cant made transponder with tag or with mercedes spe func
I finished job with gambit
shtyrya2 (5th November, 2015)
Fiat punto 188
Key learning ok
Dash calibration ok
Ecu iaw59f and iaw5af virgin ok
Read flash write ok
Envoy? de mon SM-G920F en utilisant Tapatalk
tepSIJA (4th November, 2020)
