Online key dump generation by EZS dump not working.
read and write w210 ESL via kline - OK
HeXeN (11th April, 2015)
Read cpu1 and cpu2 for W202, ignition switch via K-line working
ML programming Transponder , remote learning Work by OBD
The only place success comes before work is in the dictionary.
Dashboard ml w164 ok
Dashboard class c 2006 w203 ok
Dashboard class c 2002 w203 ok
Dashboard class c 2008 w204 not ok problem whith sam
mecafrigo (28th April, 2020)
Not much useful stuff works
DONT FORGET TO LEAVE THANKS + REP!!
DPF, EGR, O2/LAMBDA, ADBLUE, VMAX/SPEEDLIMIT, CHIPTUNING FOR PETROL/GASOLINE AND DIESEL VEHICLES!
EDC17 VAG IMMO OFF, ECU CLONING, BMW EDC17 ECU CLONING!!!
i would say 40% of wt it says it can , can do
Found in SMART ?
Remove seatbelt sound on W211 Tested OK!
correction in SMART ?
Is good for add keys but for obd?????
ISAKY - Nothing can add key by OBD on Mercedes!
A few test on mine before firmware killed it..
906 Sprinter 0KM in IC - Yes, but change language and some coding
906 Airbag ECU unlock - Succesful but cannot reprogram
639 IC 0km - works
w203 2001 IC 0km - works
ESL w202 - Read
111 ECU - Read flash and virgin - not work
CR4 (EDC16 cp31/36) not work virgin
A class VDO - Not work virgin
