is that the tv headend one,i believe it does work but needs manual updating as old links apps fail,he said he would buy the amiko a3 instead as more reliable.
Yeah thats the one - does the A3 work in a similar fashion? I did a search and couldn't find much info on them. Are there any reliable sources of the box? Thanks
one of my new haunts was a sat shop and is probably an agent for amiko as he has loads of different products .
have a look at the video guides also.Code:http://www.tvtrade.ie/amiko-a3.html
jamesndro (10th September, 2014)
Hi james.
These had a few bugs / glitches when they 1st arrived etc, I have just bought my 2nd one the other week.
I must say the latest 29/09/14 firmware goes a long way to making this a super box.
Boot up time now is seconds, new channel lists with favs, the interface is better now than my stand alone android, it also has access to my nas drive- a really great multimedia box!!
The only thing i havent sorted is extended epg- if anyone can shed any light?
Hi Sean,
Have a look at this(are u holding the vol- button as u pwr on and not release until u see the android robot loader icon on screen);
This was the firmware i used also(29/09/14)-cant upload as the file is too big(note u put in on the usb as a zip file- ie called`update`).
Also different usb drive can cause problems in a lot of makes of recievers- try formatting the usb drv/then another drv maybe also - also the file has to be not unzipped fully and make sure named update.zip(the .zip is hidden/can be seen if u right click and go to properties).
seangraves (29th October, 2014)
hi mate thankyou for that up running in a fashion im needing info on how to sort channels into favourites,,,also one quesition,,bout xbmc,,does it auto load all the addons and get them working or do i have to load every one is there a way round this thanks again
Sean,
Updated ch/fav lists;
http://www.digital-kaos.co.uk/forums...18#post2545818
seangraves (6th June, 2016)
would anyoine have the firmware to update the evoxfinity xmbc box as no matter what i do the cccam will not turn on and this is with 2 different receivers any help is much appreciated
google amiko updates will bring you what you desire.
Can buy mine my hubby left, ?30 *Removed Email Address...
