Hi all, could someone help with code for Sanyo Mazda 3 code. Numbers on radio are:
14794018
BR2D66AR0
24C02 dump attached
14794018
BR2D66AR0
24C02 dump attached
csavargo2 (30th November, 2016)
try code 3077 ????
3077 didn't work I'm afraid. Anything else?
Try code 3141
arık (9th September, 2014), Autowave (11th September, 2014), csavargo2 (30th November, 2016), masterskay62 (9th September, 2014), nelutzul40 (10th September, 2014), smoggy (9th September, 2014)
yes misread
the correct code 3141
thanks, worked a treat
arık (12th September, 2014)
Hi folks.
Can someone be help with My Radio Code, i need know PIn Code from ther same radio what is Topic
bogege (13th October, 2018), Decode Ghost (16th October, 2018), irfa (13th October, 2018), masterskay62 (13th October, 2018), shooting (13th October, 2018), smoggy (13th October, 2018)
pocinas (17th October, 2018)
I not try you file yet but... i found procedures keys to write code which is
6, AM, AUTO M and seek up. Then i provide 4 digit code 7917. And confirmed press 2 buttons together AUTO M and 6. After second is just Beeep and error again...
It is possible be was diffrent code?, chip on the mainboard looks like genuine solder, so was not touched.
What is wierd customer found card with code to radio which is exacly the same what you generated 7917 But doesnt work.
Any ideas what can be heappends or maybe diffrent code...
My post helps you? Please Hit Buttons
Please note that code entry is only possible with the ignition switched on, and in the order shown. If the display continually shows "ERR" then the unit may be codelocked and all of your code entry attempts may have been used up.
Try this.....................
Code Entry as Follows:
Switch ON the Ignition (No need to start car)
Switch Radio On - Display Shows
" COdE " Flashing
Press And Hold " Auto-M " And Preset " 6 "
The Display Will Show " - - - - "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
The Display Will Slowly Flash "CODE"
And the Radio will then Turn On
Decode Ghost (16th October, 2018), shooting (15th October, 2018)
The situation is little diffrent.
When i turn ignition on , then on the screen blinking ERR
when i press 6, AM, Auto M and finally Seek up then ERR is changed to "----" But got arround 20 sec to. starting provide code, if not start than ---- is changed again to ERR. The same is when i provide code but not accept code, than from code changing to Blinking ERR.
Radio never shows CODE. just ERR or ----
''code entry attempts may have been used up''
Who know... i tried write code like 15...20 times.
How i can reset entry attempts?
try dump from member richiebb
Decode Ghost (16th October, 2018), richiebb (17th October, 2018)
