SKP900 yes and no - Page 41
Page 41 of 52 FirstFirst ... 31363738394041424344454651 ... LastLast
Results 601 to 615 of 770
  1. #601
    Apr 2016
    uk
    Quote Originally Posted by redliner View Post
    HI did someone try to programm or pull pin code from Opel/Vauxhall cars after 2010 by the SKP900. I have tested Meriva B with no luck. I just find out that there are some options under Buick menu as the Buick Excelle is the same as Astra J and Encore i an Mokka. What will be the alternative tool for Meriva B? also question regarding Astra H - is this pull pin code or can I use Astra H to program Zafira B ? I have to prepare for programming Zafira B from 2014 not sure if Op-com can do the work can someone confirm Thanks
    Tried on few opel -2010. No luck with pin code.I use fvdi for pin code and program on opel.carprog also claims to extract pin and I've heard is working well for pin.1.3 and 1.9 diesel don't work for pin.
    Inviato dal mio HTC One utilizzando Tapatalk
  2. #602
    Feb 2017
    UK
    Quote Originally Posted by norman1967 View Post
    I updated 4.5 to 5.0 took 57 minutes
    Win 7 64bit
    I updated 4.5 to 5.0 from win7 and after 5min windows shown blue screen and reboot I had heart attack and then connect to XP update finish in 53min.
  3. #603
    Jan 2016
    Jumping Around the globe
    Last week I did an Land Rover evoque 2013, no issues, very smooth.
    Yesterday i was doing a Range Rover Sport 2014, i couldn't succeed.
    First of all there are many places in the menu where you can select Range rover sport 2014, so its a bit not clear where you should go, maybe they are all the same but still why have it under so many names/categories.
    The error i was having was always ''No communication''
    I have the 4.5 version...should I upgrade to 5.0?
    On their website i see 4.5 as the latest, then I searched on google and found that 5.0 is available but not finding it on their official website.
    http://superobd.com/SKP_900_Key_Prog...l#.WS5X2OuGPIU
    any clue?
    and would that help solve my problem with the range rover sport 2014?
  4. #604
    lion0304's Avatar
    Oct 2014
    [QUOTE=Locker;3042493]Last week I did an Land Rover evoque 2013, no issues, very smooth.
    any clue?
    and would that help solve my problem with the range rover sport 2014?[/QUOTE
    I can admise that you've have a vry big balls. See all problem between SKP900 and Land Rover, Use it for Evoque is just ......
    But very happy that you have no issue for.
  5. #605
    Jun 2016
    It does has the SKP900 V5.0 update on superobd website. Check this update notice: http://www.superobd.com/ShowNews108.html#.WS5jy9y-vIU
  6. #606
    Jan 2016
    Quote Originally Posted by Jerry523 View Post
    Yes saw that, thanks!
    but where is the download file on their website?
  7. #607
    Feb 2017
    UK
    Quote Originally Posted by Locker View Post
    The chance is 50% it's depends from if the car has dealer update if it has then "happened permanently disables the proximity function and the KVM (Keyless Vehicle Module) must be replaced." it was writen in DK some times ago.
    SKP900v5 https://mega.nz/#!LlIhyB4R!04EVxF1pu...69af9TYdtkL0-I
  8. #608
    Jan 2016
    True, the car was at the dealership last month for some repairs. Maybe in the future SKP will update in order to bypass that issue.
    Thanks everybody
  9. #609
    Oct 2013
    Just purchased the SKP-900 hoping to program Toyota G all keys lost, and it seemed it dont only works for D what a joke, my old T300 could do that!!
  10. #610
    Jan 2017
    Quote Originally Posted by Airbagtech View Post
    You can add G and H keys but you cant reset immo
  11. #611
    Jan 2017
    USA ����
    Maybe you need to update???
  12. #612
    DK Veteran elmassioui's Avatar
    Dec 2010
    Hello.today i tried nissan x trail 2016 smart key ,regestred key erased by another tools & car no start no light on dash...i use skp900 without success,programming successful. by 5 bip when programming but dash still no light..any info pls thank you
  13. #613
    Jan 2017
    USA ����
    I use ck200 for resetting immo for Toyota G
  14. #614
    Feb 2012
    Hello. i tried on Ford focus 2001 TDDI - not communication, Peugeot 307 2003 need PIN (I dont have it), Polo R 2008 - not communication. Apparently very bad for EU car or I something working bad because I am beginner ?
    apparently
    apparently
  15. #615
    newone's Avatar
    Oct 2016
    Quote Originally Posted by alkazav View Post
    apparently
    apparently
    for psa you need pin,old fords forget it,not so bad tool for its money,read the thread from the beginning
    and you will have an idea what it can do
