Can skp900 reset Toyota G
Sent from my X5mini using Tapatalk
Kia Piacanto 2007, key programming failed.
SKP900 Pin calculator gave the correct pin.
Finished the job, with a diagnostic tool.
,good for small locksmiths,literally, good but you have to have better
fang, Narwalus microcephalus,Spectrum Zx, Atari amiga, Commodore +4
2006 Buick Lacrosse. Failed to communicate selecting immobilizer4 under Buick, but also tried all 5 immo options. Was holding the transponder up to the ignition with a mechanical key in, maybe that had something to do with it but not sure. Also had jumper cables on the car to get good voltage.
Ck-200 couldn't do it either even though it has an option for this year and model. SKP1000 failed too, menu looked different than skp900, just 1 immobilizer option but failed there as well.
T-Code/MVP manual says it needs to do a 12 minute security wait, never got that far.
Had to walk from the job, left the customer the mechanical key for wasting their time
did you try 3 x 10 min????
also were you using the right key???
its b107 pk3
not b111
darknezz19 (26th January, 2018)
Saw the 3x10 min thing in the tcode manual but didn't know what that meant. Didn't even know you could add transponders keys when all lost w/o programmers with some models. Learned something here at least for next time, thanks sleepyrz.
Was using b107 pk3. For reference have you tried to add a key when all lost on this model with either ck or skp and it did the 12 min wait?
cant say that exact one but ck does them all the time 12 min wait
if not 10 x 3 works on any chevy up to 2016 in usa
darknezz19 (27th January, 2018)
Citroen C3 Air Cross 2017 Hiatg 128bits AES. Pin get from F108 one time OFF ON.
Program succesful
Citroen C3 2014, pin get from F108 one time OFF ON, key CE0523 FSK, Succesful.
LR SPort 2009 remote key with PCF7941, perfect last week. Chinese key.
Perfect learn smart key on Nissan qashqai 2009
With Tapatalk
Dodge RAM 1500 2010, read pin and program new chinese Fobik, perfect.
darknezz19 (11th February, 2018)
