Page 51 of 52 FirstFirst ... 4146474849505152 LastLast
Results 751 to 765 of 770
  1. #751
    dd1's Avatar
    Aug 2014
    Quote Originally Posted by jensen1 View Post
    Maybe it's best if we keep the comments to what it will do and what it will not do and then it will be obvious if it's of any value
    it wont do anything it says on it. i had one. worked well on pre 2000 cars. new cars, forget about it. customer service is bad, the tool is very bad, the price is the worst. do not buy. do not recommend it. and it is from my personal experience.
  2. #752
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by moddman View Post
    Any chance to make a new flash worthy signature to fool the SKP that is is getting the same file as in cloning/cloaking?
    Short verion: Forget it.
    Long version:
    Yes you have two hypothetically chances if the sign(s) uses symmetric encryption (like AES). The first thing is disassembling the skp and make a debug setup. (hw+sw) You have to start the debug, and the start the update process. In this point you have to halt the processor and starting the fun. I mean step-by-step disassembly all instructions until you will find the signature password in the memory.
    But there is a small problem. The asymettric encyption (like RSA) is unbreakable (without a sell out RSA keypair or quantum computer) and everybody is using this instead of AES.
    The second is: If somebody from the original SKP dev team sell the sign keypair and somebody in china make a third party update server to fix this problem. For good money.
  3. #753
    Jun 2017
    US
    2012 Dodge Journey Prox - Read PIN and ADDED Prox
    2015 Chrysler 300 Prox - Read PIN failed programmed with sourced PIN.
    2009 Mitsubishi Outlander Prox - Erased all Prox and programmed original and new one. IMMO 1 Under Outlander vehicle type.
  4. #754
    Jan 2017
    USA ����
    [QUOTE=darknezz19;3302323]
    2015 Chrysler 300 Prox - Read PIN failed programmed with sourced PIN.[\QUOTE]
    even mvp pro with smart dongle cannot pull this pin
    only AD smart pro can do a bypass.....
  5. The Following User Says Thank You to sleepyrz For This Useful Post:
    darknezz19 (12th June, 2018)
  6. #755
    Nov 2015
    UK
    Watching this for my own interest
  7. #756
    Nov 2015
    UK
    Quote Originally Posted by sleepyrz View Post
    Just saw a video of someone programming a 2011 Ford Transit connect under focus immo2 and it worked perfect
    In SKP i use Transit 2010 >
    This is the blue remote & i have programmed no problem at all
  8. #757
    Nov 2015
    UK
    Quote Originally Posted by ford2002 View Post
    yes you right i programming for ford fiesta under focus and it work
    There are a few that if you have no success Focus will work.
  9. #758
    Nov 2015
    UK
    Quote Originally Posted by didi_du_93000 View Post
    Citroën C1 2009 (on base of Toyota Aygo)
    Full working for adding key. Not tested for all key lost.
    No need any pins. All is automatic. But the tool ask to put new key and DON'T turn ON ignition for 1 minute. But it's an error, You MUST put On ignition.
    With Tapatalk
    How did you find this out ?
    Did you follow screen instructions where it failed then you tried with put ignition on ?
  10. #759
    Nov 2015
    UK
    Quote Originally Posted by SKYTON View Post
    no one tryed to flash this device ?
    You will need to look on the internet but there are various files depending if skp had tokens left or was at 0
    You then install the correct V5 then install the V5 little file.
    I did it and now my message "you can use 8 times" has gone.
    I have used it many times since.
    I cant advise where i found the files but only took 30 minutes to find.
  11. #760
    didi_du_93000's Avatar
    France Paris
    Quote Originally Posted by Buddy41 View Post
    I have tryed what screen give me and don't work.
    With Tapatalk
  12. #761
    2014 mitsubishi asx prox key done in seconds
  13. #762
    Default smart car 451
    can or will it do smart 451 keys ?
  14. #763
    newone's Avatar
    Oct 2016
    Quote Originally Posted by martin1234 View Post
    yes it can
  15. #764
    which one though skp900 or fvdi ? will do all lost keys ? ,
    i think i favor fvdi , it seems to be quite a popular option to buy,
  16. #765
    newone's Avatar
    Oct 2016
    which one though skp900 or fvdi ???
    here is a thread for skp so skp can do,fvdi also
  17. The Following User Says Thank You to newone For This Useful Post:
    martin1234 (22nd June, 2018)
