New Chrysler / Dodge / Jeep with RFH SKP-900 WILL NOT program a key with correct pin code (will not read the pin too). Shows negative response.
Job done with latest WiTech 30 seconds, no problem.
Best Regards, Roth.
THE BLOCKER TO PROGRAMER KEY IT QUICK AND GOOD
i am surprised to know skp cannot program any pats 3 immobilizer
tired with mustang 2009 , didnt commnuciate. i realized there is option for Pats 3 in the skp for whole ford. can anyone confirm my observation?
which option was can you share with us for all member for ford pats systeam
sleepyrz (9th May, 2017)
toyota rav 2004 all lost key does not work 4c transponder says reset 5 seconds do you want add another key adapting failed tried under other models too waste of time .
That's why I have ck.....
2013 Lexus ct200h prox fail
2011 Hyundai sonata 2.0t prox fail
done with mvp pro
2011 hyundai sonata prox failed on me almost three times
on menu says toyota rav europe 2003 to 2009 lost key or add key .
4c ended in uk on 2003 rav 4 models and id67 took over , as with any cross over period you will see both on 2004 year as not all cars registered in 2004 were actually assembled and built in 2004 , so 2004 will always be a year you could see either or .
comizelu (11th May, 2017)
2013 Dodge Grand caravan USA fobik
Skp900 pulled pin code and programmed in 5 seconds
Obdstar x300pro3 failed
Ck200 failed
HI did someone try to programm or pull pin code from Opel/Vauxhall cars after 2010 by the SKP900. I have tested Meriva B with no luck. I just find out that there are some options under Buick menu as the Buick Excelle is the same as Astra J and Encore i an Mokka. What will be the alternative tool for Meriva B? Thanks
rob h (27th May, 2017)
