Results 1 to 15 of 19
    Lithuania
    Default Audi A6 crypto dump
    Need crypt dump from 93C86 Audi A6 4B0920981J v.D12 or can crypt original?
    jr59's Avatar
    LILLE, FRANCE
    donoras anglas orig crypto.rar ori crypto try this
    NEW SMOK PSA,PSA XS EVOLUTION CLONE, KTAG 2.13 CLONE, CARPROG CLONE, GALLETTO 2 V50 CLONE, UPA-USB CLONE, AND BRAIN.EXE!!!
  3. The Following 2 Users Say Thank You to jr59 For This Useful Post:
    leandroks (27th July, 2016), Min2xx (3rd October, 2014)
    Lithuania
    Not working Problem not solved ....
    jr59's Avatar
    LILLE, FRANCE
  6. The Following User Says Thank You to jr59 For This Useful Post:
    Lithuania
    Not working Same...
  8. #6
    jr59's Avatar
    LILLE, FRANCE
    try SWAP!!
  9. The Following User Says Thank You to jr59 For This Useful Post:
    Min2xx (22nd August, 2015)
  10. #7
    Lithuania
    Now working with V1 swap, but have sound and DEF, think need crypt orig, but how?
  11. #8
    WW
    i think is not cripto, only few version, download more dash dumps and try all
  12. The Following User Says Thank You to elephantul For This Useful Post:
  13. #9
    4b0920981j
  14. The Following User Says Thank You to koyot For This Useful Post:
  15. #10
    Lithuania
    It's not crypted dump. I have original, need crypt it!
  16. #11
    yugo45's Avatar
    Write it OBD and it will be good.
  17. The Following User Says Thank You to yugo45 For This Useful Post:
    Min2xx (5th October, 2014)
  18. #12
    Quote Originally Posted by yugo45 View Post
    That's not working on crypted VDO A3/A4/A6 dashs. Once eeprom is damaged you need to write dump with correct crypto first.
    Around 10-12 version are existing. Repaired several of them. Try&error. once it is working again, you can write the dump via obd
  19. The Following User Says Thank You to exe123 For This Useful Post:
  20. #13
    gogalv's Avatar
    Aug 2010
    Thys or SWAP.
    4B0920981J v.D12.rar
  21. The Following User Says Thank You to gogalv For This Useful Post:
  22. #14
    Lithuania
    Swap dump from jr59 and dash working, see def in km. Changed km with FVDI, reconnected cluster, and all Ok, but can't learning to car. End made immo off in ECU, and car start! Problem solved, thanks to all
    PS you can not write back orig dump by OBD if you not have encrypted!!!! other dump working in cluster, but can not bee learning to ECU, only immo off!!! If you want change cluster with immo 3, read pins and change like in ross tech.
    Thanks to all DK members to help
  23. #15
    yugo45's Avatar
    You can not learn it in ECU because Audi A6 cluster has to be in Virgin New mode to be able to do this.
