Hi ALL!
I'm very need original dump for this ECU.
Also may be any like for this type of engine - 1.8 6FY
Thanks in advance!
Hi ALL!
Thanks in advance!
here u go.........
Imagination is more important than knowledge, because knowledge is limited ... while imagination creates the world.
Very BIG THANK!
Unfortunately it does not work. Likely ECU has been replaced. PP2000 sees ECU as 2.0 RFJ, but I need 1.8 6FY. I found the correct picture, please I really need a dump
Anybody can help me?
here you goo ST10F280 for 6FY motors petrol 4 cylinder manual gear at 100% ,
use it and let us lnow result.
pass in u pm already
Thank you! I'll try it tomorrow, be sure to let you know the result!
Anatoliy, hi friend. You solved this problem?
Official reseller MMC-Flasher in Belarus.
Here u go ....... autoelek
br
autoelek (19th April, 2015)
hi to all , i have problem with the same ecu mmIAW 6LPB PEUGEOT 407
HW16.707.254 9663805380 SW16.882.034 9664922380 ,i read mcu st10f280 with orange5 programmer,
i need good dump
thank you very much for any help
Hi mate , here u go with this file but u need coding with pin from bsi.we wait for result
best regards and good luck
pass in u pm
kitachu (26th June, 2019)
