Page 6 of 15 FirstFirst 1234567891011 ... LastLast
Results 76 to 90 of 219
  1. #76
    Jan 2012
    Default BMSKP 8
    Hi please help to calculate mileage , original is 26,862km and need 8,150km
    Best Regards
  2. #77
    sida's Avatar
    May 2014
    System32
    Quote Originally Posted by Niaz View Post
    What is this, S1000RR?
    Here try it Attachment 523460
  3. The Following User Says Thank You to sida For This Useful Post:
    Niaz (24th April, 2018)
  4. #78
    Oct 2015
    Friend, how to convert 2mb file(*.bin) to *.dim file? Using bdm-100
    Quote Originally Posted by sida View Post
    File 1 should work, if not try file 2 and let me know...
    Attachment 523142
    Attachment 523143
  5. #79
    Jan 2012
    Yes mate S1000RR HP4 , your file is ok thanks again
    Best Regards
  6. #80
    sv2hqx's Avatar
    Jun 2014
    hi
    can you calculate this too
    r1200 2011
    original 86534
    new 12012
    thank you
  7. #81
    Oct 2015
    sv2hqx, could you help me? Are you using bdm100? im trying to write bin file, it it writes only *.DIM files
    Quote Originally Posted by sv2hqx View Post
    hi
    r1200 2011
    original 86534
    new 12012
    thank you
  8. #82
    Port Elizabeth
    Default gs800 change vin and mileage
    Hi can someone please change mileage from ecu to cluster and change vin bike was in a accident and I replaced cluster dont know what mileage is in ecu last service was done at 46000km
    Shane
  9. #83
    sida's Avatar
    May 2014
    System32
    hi
    r1200 2011
    original 86534
    new 12012
    thank you
    Mate here you can try 12012, will see...
    Attachment 523722
  10. The Following User Says Thank You to sida For This Useful Post:
    sv2hqx (26th April, 2018)
  11. #84
    sv2hqx's Avatar
    Jun 2014
    Attachment 523722
    thanl you............ worked
  12. #85
    Port Elizabeth
    can somone please tell me what the mileage is on ECU
    Shane
  13. #86
    sv2hqx's Avatar
    Jun 2014
    [QUOTE=sida;3268771]Mate here you can try 12012, will see...
    hi again
    can you check km on this ecu?
  14. #87
    cokolo's Avatar
    Oct 2010
    Springfield :-)
    [QUOTE=sv2hqx;3274305]
    hi again
    You have 207946 km
  15. The Following User Says Thank You to cokolo For This Useful Post:
    sv2hqx (3rd May, 2018)
  16. #88
    sv2hqx's Avatar
    Jun 2014
    [QUOTE=cokolo;3274357]
    You have 207946 km
    can you calculate to 14168?
    thank you
  17. #89
    sida's Avatar
    May 2014
    System32
    ...........Attachment 526316
  18. The Following User Says Thank You to sida For This Useful Post:
    sv2hqx (6th May, 2018)
  19. #90
    sv2hqx's Avatar
    Jun 2014
    hi
    please calculate to 8068
    old mileage 80547
    r9t 2016
    thank you
