Results 1 to 11 of 11
    einet's Avatar
    Default 8K0959655B A4 B8 2008 Checksum error
    I have a A4 B8 from 2008 to cleare or repair the airbag light!
    Have this errors on airbag! (in the moment i have problems with my tablet, that i use another OBD)
    U1012 Supply voltage too Hight
    B2000 internal control module memory checksum error
    This car have Component protection and i need someone that have this problem and have it resolve!
    or a virgin file or a correct file whose great!
    einet
    DK Veteran easternghost's Avatar
    Mar 2014
    Default a4 b8
    cleared
  3. The Following 2 Users Say Thank You to easternghost For This Useful Post:
    eeprom241 (16th February, 2018), Ginocar (12th November, 2015)
    einet's Avatar
    I become the same error again and the checksum is gone!
    But become internal module foulty and the "U1012 Supply voltage too Hight"
    how knows more about this "U1012 00 [137] - Voltage too High" on audi airbags?
    DK Veteran jruibarroso's Avatar
    Dark Side of the Moon
    Hi , already have this fault ("U1012 Supply voltage too Hight") on a airbag unit and couldn't managed it
    The solution was get one used and adapt component protection with VCDI
    All of my posts are for educational purposes only.
    If this was helpful to you, please press THANKS
  6. The Following User Says Thank You to jruibarroso For This Useful Post:
    einet (10th October, 2014)
    whim's Avatar
    Feb 2011
    Clear dump replace your ecu
  8. #6
    einet's Avatar
    Thanks,
    But you say cleare dump and change ecu?
    Is it correct that you say that i cleare the dump and load this dump to the new (sraped) ecu?
    and this work whit component protection?
  9. #7
    einet's Avatar
    any sogetions for this problem?
    And nobody that have AVDI can say somthing?
    This is for a good frend of me, that help me.
  10. #8
    einet's Avatar
    and no-one?
  11. #9
    i have same unit with crc error..need asistance
  12. #10
    alclot's Avatar
    Melee Island
    Hi jruibarroso. I have a few questions. I´m triying to manage this airbag unit. Can you share how adapt component protection with VCDI? Can we change codification (I tried with avdi and vdcs only with and it disnt work? Can I do this only with unit?
    Thanks in advance
    Quote Originally Posted by jruibarroso View Post
  13. #11
    alclot's Avatar
    Melee Island
    Hi again. Can anybody help with how change codification of this unit?
    Please help ;(
