Page 9 of 28 FirstFirst ... 456789101112131419 ... LastLast
Results 121 to 135 of 417
  1. #121
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by ibrasport View Post
    hi to all i want help for make immo off for ssangyoung rexton .
    A665 540 17 32
    DCM3.2AP
    REXTON 27DT-DPF
    95320
    28169316
    THX
    Your file in the opened thread.
  2. #122
    Jul 2010
    POSSIBLE TO IMMO OFF DCM 3 95160
  3. #123
    May 2014
    Default rexton immo
    HI.
    CAn someone help with immo off?
    This is my first rexton 2.7 with delphi ecu.
    EEprom readed via bdm ktag.
    P.S. Ktag read this eeprom like 95320 but this is 95160.
    Read this eeprom 2 times... so file is repeat 2kb
  4. #124
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by rafalgt View Post
    HI.
    Here you have 2 files oFF. See instruction.
    Your file is weird. Pass PM
  5. The Following 2 Users Say Thank You to lion0304 For This Useful Post:
    rafalgt (20th April, 2018), tuningschool (20th April, 2018)
  6. #125
    Jul 2010
    why noone help me please?
  7. #126
    Dec 2014
    LOCATING
    Hello Frieds..
    One of my ssangyong tivoli 2016 not starting after the accedent.
    1. No respoce while pressing the Push button.
    2. Inteligent key is ok.
    3. hazad, and head light can be oparate.
    4. Remote lock/unlock not working.
    5. All fuses ok manually checke and confimed.
    6. can observe one indication of the small light in push button, but not activating even while pessing the push button.
    7. Battery ok, Grounds ok .
    Note, No service manual available to check further. If anybody can hep, it is highly appreciated.
    Sanjeev
  8. #127
    Jun 2016
    Default rexton off
    Hello
    can someone please help me with the immooff of this file.
    Thank you
  9. #128
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by minomino View Post
    Hello
    Thank you
  10. #129
    Jun 2016
    Not everyone is materialistic.
    I will wait to see if someone will help me without anything in return.
    This is not even mine. I'm also trying to help a friend.
    thank you anyway
  11. #130
    Oct 2014
    Hi Guys
    I need some help please with a SsangYong Rexton 2006 Delpi ECU with the 95320 eeprom.
    Can anyone help with immo off please.
    Many thanks in advance.
  12. #131
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by sonicevo1 View Post
    Hi Guys
    See instruction, write file oFF and start the car.
    Pass ask PM. There are no MONEY when you ask for HELP!!!
  13. The Following User Says Thank You to lion0304 For This Useful Post:
    sonicevo1 (2nd June, 2018)
  14. #132
    Oct 2014
    Quote Originally Posted by lion0304 View Post
    Worked no problems at all..............many thanks Lion0304
  15. The Following User Says Thank You to sonicevo1 For This Useful Post:
    lion0304 (6th June, 2018)
  16. #133
    Apr 2010
    Russia
    Help make immo off please. Ssangyong Action Sports 2.0XDi 2008 y.
  17. #134
    May 2017
    plise pasvord thanks
  18. #135
    garciaefren's Avatar
    Sep 2010
    colombia
    Default rexton2 help
    help rexto2 colleagues
    I do not know the identity of the transponder and it does not communicate with xtool pad2 pro by type but do not program try with id 48 and id46 please immo off
