Someone has some solution to immo off a ecu delphi of a sangyong REXTON?
A6655400132 DELPHI
Attachment 281742
here your immo off. clean up your PM box, then your get some instructions.
Don't Forget Button
Abdo Abdelatif (23rd April, 2018), abdomm (13th April, 2016), abrhem (28th June, 2015), accura (8th June, 2021), alfredoivan69 (16th February, 2016), ampibali (21st November, 2022), art64 (10th December, 2021), Autronico2 (22nd April, 2022), Barendjoubert (27th November, 2019), bobyneal (12th June, 2019), criss2000 (6th July, 2015), Donabe (13th April, 2021), eleeinidis (6th July, 2015), estwood68 (9th August, 2016), GaizkaV8 (16th October, 2014), giani67 (5th December, 2020), guliver21 (15th September, 2020), kyawkyaw (28th December, 2018), Laca06 (4th March, 2021), lfpossamai (9th October, 2020), lion0304 (4th July, 2015), manan01 (10th July, 2016), marcosbgarcia (18th January, 2016), mcday (14th October, 2017), mohamedkey (14th March, 2015), MRAWZIN (18th February, 2018), ocakdan55 (12th June, 2021), pandokrator (13th July, 2015), rachmach (18th June, 2015), redsuns (25th December, 2021), serbi (6th December, 2018), STEEVYAS (30th June, 2015), systemlinux (18th October, 2019), Tyson500 (22nd April, 2024), xifly18 (13th May, 2015)
Many many thanks to Lexar!!!! it start perfect
very good Lexar
Dear,
I have a SSongyong having the calculator burned when battery polarity was inverted accidently.
The car doesn't start .
Its ECU is : A6465408432 - eeprom 95320
The new ECU : A6465404632 - eeprom 95320
I nedd immo off (virgin 95320) for the second ECU.
Thanks.
Post Your dump from new ecu
This is my dump
95320 sangyong .rar
here your immo off. first disconnect immo box, then plug in ecu.
Don't Forget Button
Abdo Abdelatif (23rd April, 2018), abdomm (13th April, 2016), abdou elec (3rd December, 2014), alderik789 (9th February, 2019), all4 (19th April, 2022), ampibali (21st November, 2022), Arnold42 (26th September, 2018), art64 (9th December, 2021), Autronico2 (22nd April, 2022), Barendjoubert (27th November, 2019), clauberty (10th January, 2018), digikeys (29th May, 2016), Duwagemadusanka (25th March, 2023), estwood68 (21st April, 2019), giani67 (5th December, 2020), guliver21 (15th September, 2020), houdiag (11th April, 2018), Laca06 (4th March, 2021), MAMBOKING (3rd June, 2023), mcday (14th October, 2017), mohamedkey (14th March, 2015), mukasa mathew (16th September, 2022), pandokrator (13th July, 2015), samejama (13th December, 2019), seifou (1st December, 2014), systemlinux (18th October, 2019), Toutancamon (10th April, 2018), VVDI (16th October, 2019)
Dear Sir,
Many thanks for your help.
I removed the immobox form the ignition barrel, and then I mounted the ECU.
I tried your solution but the car does'nt start.
Have you any another idea or file?
This solution should work. Its tested many times. make sure you write eeprom properly or your eeprom still good. try to delete all faults in ecu, program and solder new eeprom, double check soldering points. make sure your ecu still connects with diagnostic tool. what faults did you get in ecu. had one ecu dead after play with eeprom...
Don't Forget Button
art64 (9th December, 2021), elephantul (2nd December, 2014), key (19th January, 2016), Laca06 (4th March, 2021), lion0304 (4th July, 2015), martinracing (15th November, 2017), pandokrator (13th July, 2015), systemlinux (18th October, 2019)
if Lexas have a penny for every immo off ssangyong make in dk, must have enough for a week holiday in Bahamas
Lexas (3rd December, 2014)
hi
i have immo probleme for ssongyong actyon sport ecu delphi DCM3.2AP eprom 95320 , ineed immo off
ssongyong actyon sport immo probleme 1501.rar
Can someone help me
abdomm (13th April, 2016), ampibali (27th October, 2020), Autronico2 (22nd April, 2022), delio78 (16th March, 2020), estwood68 (9th August, 2016), khadim (28th June, 2022), mot 1 (2nd January, 2024), pakman (16th January, 2015), pandokrator (13th July, 2015), Redoc (30th June, 2023), STEEVYAS (30th June, 2015), systemlinux (18th October, 2019), VVDI (16th October, 2019)
thanks Lexas , the car starts but does not accelerate
Barendjoubert (27th November, 2019), pandokrator (13th July, 2015)
