Page 2 of 7 FirstFirst 1234567 LastLast
Results 16 to 30 of 91
  1. #16
    Every thing what U need is in this thread. Adaptation in chanel 33 . and connect cable in white and yellow plug from tacho.
  2. The Following User Says Thank You to yokazik For This Useful Post:
    Gagik1984 (30th March, 2017)
  3. #17
    Jun 2017
    Default Tachograph Removal
    Quote Originally Posted by vagdiag View Post
    Adaption 33-0, Disconnect tachograph. Plug yellow/ black wire B1-100ohm resistor 12v, B2 red wire ground, B3 brown wire speed signal to B8 white/blue wire. Thats it.
    When you say plug yellow/black wire B1 100ohm resistor, do you mean the resistor goes between the yellow & black wires please?
    thanks T
  4. #18
    Jun 2017
    Hi all, I have removed the tachograph from my 2006 VW T5. I set 33 & 0 in adaptation, & the mileage has reappeared on the speedo. I connected the brown wire (B3) to white/blue wire (B8), soldered a 100 ohm resistor between the yellow wire (B4) & the black wire (B1), & the red wire (B2) to ground as in vagdiag's description. The speedometer still doesn't work. The red wire, btw, reads 8 volts? & you say it should be earthed?
    Any help appreciated please!
  5. #19
    Feb 2015
    Can work on a dash vdo polo classic 93c46, I have problems with tachometer.
  6. #20
    May 2018
    This is just what I was looking for. I know it has been long ago, but I just got a T5 with that tacograph and I'm looking for a way to remove it, I am not going to use it at all.
  7. #21
    Quote Originally Posted by konq100 View Post
    Problem solved. Thanks!
    how did you solved?
  8. #22
    Feb 2013
    Hello, I would like to remove tacho since its not going to be used anymore.
    After following instructions from this thread I got mileage info back on the cluster but speedometer does not work. Is it necessary to modify file in this case?
    File attached.
  9. #23
    Mar 2013
    Spain
    Quote Originally Posted by mcd76 View Post
    are you telling us how you did it?
    Please let me know your solution. I have the same problem here.
    Thank's in advance
  10. #24
    Jul 2011
    Portugal
    Post dump 93c86
  11. The Following User Says Thank You to rimljan For This Useful Post:
    mcd76 (24th September, 2019)
  12. #25
    mcd76's Avatar
    Apr 2012
    BT Romania
    Quote Originally Posted by autepo View Post
    Thank's in advance
    you have a mesage....
  13. The Following User Says Thank You to mcd76 For This Useful Post:
    autepo (24th September, 2019)
  14. #26
    Oct 2019
    Quote Originally Posted by vbrav87 View Post
    Hi there people,
    I just joined this form as I see there is a lot of info here about T5 vans. I am in the same situation as some of you - wanting to uninstall the tacho from my T5. I did the adaption 33-0 and got rid of the "T" in the dash and also re-enabled odometer but speedo is still dead. Am curios what you guys post in the attached archives. Is it just the wire manipulating left to do to restore speedo?
    Another question to those who did the adaption 33-0 and the wire job, did you encounter any side-effect on the instrument cluster or the car behaves just like one that never had a tacho?
    Thanks and cheers!
  15. #27
    Hi, I have a similar problem with a t5 from 2015 year, could someone help ? Thanks
  16. #28
    Dec 2016
    Default Tachograph of for T5
    Hi mate, can you pls. do Tachogroph off vor my dump. Speed and Fuel dont work.
    thanks mate
    @Inquizit0r
  17. #29
    Romania
    Did you disable from adaptation? Post eep of dash
  18. #30
    Feb 2018
    Default Please Help me tachograph Off
    Quote Originally Posted by ghitab View Post
    Hi dear Group
    I have VW T5 Year 2007 with Tachograph , in VCDS i change in Chanel 33 from 1 to 0
    Now Trip shows in cluster but km/h not work
    i have read the Cluster eep 93C86
    Can anyone help please
    THX Very much
