on this image how do i get bt sport extra channels into a bouquet?
I have got "sports" and "sky sports interactive" bouquets, but not "bt sport interactive"
with remote they are 50367/8
Hi all,
This is by far the best image for Dreambox. I do have a question though. I used to make use of Enigma TV, an application that allows you to watch your Dreambox on a PC with a nice interface as well. Although after I installed the Commanda image, I can no longer connect to the box, although the box can be accessed via a web browser.
Is there some form a lock preventing me from accessing the Dreambox with Commando via an app. I have spoken to the developer who advised that if you can access the Dreambox via a web browser then you should also be able to do so via the app.
Any help would be much appreciated.
John.
Not sure where to go with this, but have commando image installed & have added a CCcam but when i go blue-menu-red into softcam menu it says CCcam installed but it keeps switching it off when i try to activate it, sorry if in wrong section.
reflash to the latest version commando and add in everything u want to then check your ip address on the box and use firfox to access that ip address. also make sure vlc player is installed on you pc or laptop to be able to watch the stream. hook the box to the routerdhcp enabled
Would I be able to flash my old Dbox2 C, with this image?
Currently Commando 10![]()
Have full ver Ross-Tech Vag Com.
Excellent, not checked any dm500 posts for yonks, does this require an Internet connection or does it do all the work itself
is there a tutorial on how to flash this image?
Same as any 500 image mate
Dream up with a 232 cable .
Or if theres an image on it now transfer to temp and upload via remote ...........Paul
PAUL
digicon (25th August, 2015)
Im trying to use the Network in DreamUp to flash this image but when I turn my dreambox it doesn't see it?
Better to use a Null modem cable on its own or in conjunction with dreamup
elrasho (29th August, 2015)
just stumbled across this - need to try out this weekend, see if i can do more with a box collecting dust :-)
Same here.. Must have a play around this evening..
Guys- this image is now 'State of the Ark' !!! Please flash the latest C15.1c release, which is 25th November 2015 build and stickied at the top of this thread.
Cheers- AL![]()
00360362878 (28th November, 2015), satsmo (27th November, 2015)
