albonidao (11th February, 2019), Linhhyundai (2nd April, 2020), luco7 (7th November, 2014)
hi all
i made interface FLASHit like in the website officiel
Anbindung an FLASHit
but i need some configuration in port com to detect my interface,if some one using this tool plz give help.
thank you
I do this tool too, but on table I can talk with c167cs-lm (desoldering chip) from sirius 34 (foto), but with sirius32n on board no. And I think something is with oscillator because leg 138 go to xtal1 directly but leg number 137 - xtal2 go to resistor 102 (1kohm) and after that to oscillator. If I connect resistor 102 with leg 137 to chip (like in sirius32n board) on table than no communication, but without no problem. What do You think about that.
Dear friend,
have you maybe a full working combination FLASHIT 9 and crack? I tryed 4 versions (9.0.2.8, 9.2.0.5, 9.2.9.4, 9.3.4.9), and none of them works, every version with crack can write only 4kB, and stops at first memory sector. I have Infinion C165 with external memory. FlashIT can erase memory (full and sectors), but it can not write to external memory (fails in first sector).
Please help!
I think yes but must check - because old post.
Wysłane z mojego SM-G386F przy użyciu Tapatalka
So, any news about FLASHIT 9?
Kind regards!
Work version: http://www.digital-kaos.co.uk/forums...l=1#post750123
KahN (9th August, 2017)
Serg1o
It seems that cracked FlashIT versions works with chips with internal memory, but doesn't work with chips with external memory.
I am also in the same situation. can help me not much thanks
