Results 1 to 15 of 20
    Fec001's Avatar
    Default Reading problem EDC15C7 Ducato/Boxer/Jumper by OBD
    Hi!
    Anyone knows what could be the problem while trying to read these cars by OBD?
    China galetto2 can't read, Galetto EU v54 can't read, KWP can't read.
    It's very annoying I have to desolder flash all time I get a van with this ECU.
    Vasily.U's Avatar
    Belarus Minsk
    Not need desolder flash, just read in boot mode.
    Fec001's Avatar
    Put boot mode doesn't help. Cannot read in boot mode either.
    Vasily.U's Avatar
    Belarus Minsk
    It's strange, i use mpps china clone and all ok.
    Fec001's Avatar
    OBD or Boot?
    Vasily.U's Avatar
    Belarus Minsk
    Usually OBD, if without car boot.
    Vasily.U's Avatar
    Belarus Minsk
    Maybe problem in drivers or com port settings ?
    Fec001's Avatar
    Don'T know, every other type works perfect with v54. Only Honda EDC16 is the other type what can't be done through OBD, always have to do by BDM. If fomeone know solution maybe will share
    Jul 2011
    Bulgaria
    This Ecu can easy read by boot mode with mpps galletto 2 dont work !, you need to deslder immo eeprom in back side of the ecu, to read by boot!
    Fec001's Avatar
    I got that info about desoldering immo eprom before. Next time will try that, but first ask about why it doesn't goes by OBD
    Jul 2011
    Bulgaria
    Because your immobox not working and disable to download by obd
  12. The Following User Says Thank You to k1champion For This Useful Post:
    Fec001 (6th November, 2014)
  13. #12
    Fec001's Avatar
    So when there is immo problem, then not possible programming by obd?
  14. #13
    miha99's Avatar
    EU
    YES or make immo off and you can read ECU without immo box.
  15. The Following User Says Thank You to miha99 For This Useful Post:
  16. #14
    Nov 2013
    UK
    Just desolder eeprom and all be ok.
    DONT FORGET TO LEAVE THANKS + REP!!
    DPF, EGR, O2/LAMBDA, ADBLUE, VMAX/SPEEDLIMIT, CHIPTUNING FOR PETROL/GASOLINE AND DIESEL VEHICLES!
    EDC17 VAG IMMO OFF, ECU CLONING, BMW EDC17 ECU CLONING!!!
  17. The Following User Says Thank You to tunertool For This Useful Post:
  18. #15
    overs0ull's Avatar
    Nov 2012
    near the sea ... ;)
    yes i have the same problems like this with this kind ecu but with desolder immo eeprom all is fine in boot mode with MPPS v12 ,and is litlle bit easy of this to desolder the flash .
    Chiptuning/DPP/EGR/LAMBDA(O2)/FLAPS/Adblue/DTC OFF / EDC17 Immo OFF
    Kess v2 eu. clone full/Ktag eu. Clone 6.070 full
    Info on pm
    Kess v2 ori , K-tag ori, MAGPro2 x17, Galleto v54 EU ,Winols ,AVDI full ori, Orange 5 /Omega /Xprog/Upa all ori , VAS Pc , Porsche PIWIS 2 and etc........
  19. The Following User Says Thank You to overs0ull For This Useful Post:
