Results 1 to 7 of 7
    Nov 2014
    Default ECU swap Audi a3, need pin, any help?
    So I have an Audi a3 1.9tdi 110bhp yr/2000.
    How can I get access to the pin? I have VAG-com to install ecu but don't have pin of either ecu as it is a sechond hand one.
    Any software out there cheapish?
    vvv cheap K can commander 1.4 will get u the pin via OBD.
    PS why do you need it? u cn also make immo off from eeprom. same cable aslo does immo off
    Nov 2014
    I don't know basically I need to put the sechond hand ecu brought of a scrapers into my car and have it work with my car as my immobiliser is in my instruments, is there another way of doing it?
    ohh yes of course, easy way.
    desolder immo eeprom from old ecu and solder in new one. and taht is it. no need for anything else!
    Nov 2014
    Legend have you got a pic of what the immo EEPROM looks like ? Also is there any way I can back up my ecu I have vag-com can I use that or not ?
    Vasily.U's Avatar
    Belarus Minsk
    EEPROM looks like picture
    all u can use for back up is read eeprom with programmer and flash with any obd tool, or externally with programmer too!
    Vag com wont do taht
