I tryed to unlock the firmware on my FVDI but with wrong ID
Now i have error 4 and the units led flash.
I need for repair my unit firmware with ID F08151
only .DB et .FW file in FWdownloader
Hi!V3 or v4 pcb?if you have v3 krew to help he have firmware generator.
Interesting this was the issue I was looking for some one to start the process for unlocking ways....
Do you know someone who have fw generator?
Error 4 is wrong firmware in interface you need fwdonloader to upgrade correct firmware inside.
Loked interface .
The KG is somewhere in Poland . And no selling area here.
dont talk a lot and nothing
Hi M8,
Interface is not locked after that, you can write new fw and db files, the problem is find those with your own serial number.
Regards.
gopelhu (29th January, 2015)
Hi all,
Here are the generator and downloader.
I use xp prof sp3 and generator works perfectly but downloader NOT.
Errormessage : FlsGetValue in kernel32.dll... xp sp3 use only TlsGetValue.... grrrrrrrrrrrrrrrrrrrrrrrrrr
I cannot upgrade my kernel32.dll, why?
Regards,G
2m2c (6th May, 2018), agustino (22nd November, 2015), alhashimi71 (19th December, 2016), angelosk (13th October, 2017), artkiani (22nd February, 2016), Brown012 (24th March, 2022), Col19 (2nd February, 2021), dziongas (26th January, 2017), electronistul21 (1st April, 2019), estwood68 (8th January, 2020), guliver21 (17th May, 2020), hmagga (1st January, 2018), houdiag (24th September, 2018), Ilias27 (31st March, 2019), leotdx (20th March, 2018), lstuning (4th March, 2017), miha99 (17th October, 2017), MRAWZIN (9th July, 2019), popescuvali (13th December, 2021), Sotirov (1st May, 2016), Stelaras (8th June, 2017), tekn95 (30th December, 2016), toolz78 (6th July, 2020), ultim4te (10th May, 2017)
I have an update for fvdi V4 id: F04881 for Ford and Toyota
https://yadi.sk/d/W5OY3urDbu55n
thank you gopelhu l fix my device with your software
Hello
Can anybody share fw for ID: F06286?
Does anyone have the firmware for A07023?
Thank you for that!
give me some help, i need firmware for id F12252
