send me number ezs
I have read the mcu data from a w203 ezs and I found all keys disabled. Car had sudden problems and both keys of car stopped working same time. Mcu is the classic problematic motorola 4J74Y mcu. I searched the forum and I found two threats of people had same problem. Somebody tried to enable again the keys at both cases but worked only for one case. Is it possible to repair data for my ezs?
I have to write them on a new 4J74Y ecu and make keys, but this I can do it. I need someone to fix my data.
This file below contains only data from eprom memory
4J74Y original keys disabled.zip
I have two last questions
1) Can I use other mcu with mask 2J74Y or other ?
2) I have to program both eeprom and flash memory of a used mcu?
Thanks in advance
send me number ezs
He's asking for EZS part number (ex: 203 545 01 08, 203 545 05 08, 209 545 19 08, etc)
Working on something to release next month for free for all dk users :>
Nik Matsa (10th November, 2014)
your file all keys enabled
I have had a bad experience with Fly ....
I noticed by the hashes that they were obviously used. I just dont know what those bytes mean. And skc only checks first bit so its also inconclusive.
You can see in my file, pass im PM.
thanks both of you for help, I ll try smayer's solution and I will report results
pitake (12th April, 2018)
I tried smayer solution but didn't worked. When I mounted ezs on the car I car didn't respond to key. A new problem appeared too, I couldn't see mileage on dashboard.
After I mounted ezs I read again eprom data from ezs and I noticed differences. Differences where in the first lines of data.
This was the procedure I followed :
1. I replaced the original 4j74y mcu with 2j74y mcu from a used ezs.
Car's ezs had an 4j74y on the front side and 2j74y on the back side.
Spare ezs' front mcu was missing and at the back side had that 2j74y which I used to replace 4j74y mcu.
2. I programmed only eeprom memory of 2j74y with data fixed from smayer.
Should I had to program and the flash memory?
If yes where can I find data to program the flash memory of 2j74y?
What programmer are you using?
ak500+. I read again mcu after writing and verified data written and was ok. I have programmed before that type of mcu's via ak500+ and I had no problem.
Hi mate ETL TOOL best for 908 mask. Read eeprom data only and it works perfect
Just EEprom data don?t work if mcu is from diferent position (pcb side). Easy solution is use mcu from same position and write just eeprom you can use 1J35d.
I found 1j35d from a used ezs same position. I will program the data you sent me Smayer and I will check the ezs tomorrow on the car. I will report results tomorrow
