Test this bin
Test this bin
jaelgti (21st November, 2017)
test2 pass the same
try this one ....if you do not solved
have idem problem dtc P1640, car running and started , solament dtc diagnosy ! possible resolv damp upload orginal eprom reader
hi
i have error config eeprom in 0 281 001 445 EDC 15M (DDE3)
power from 1000-1500 RPM
I was called today to help starting a 320 E46 2.0 Diesel that have its pump replaced.
The car cranks but does not start. The following are the DTCs that can not be erased.
Any ideas please?
Knowledge is to share... so if I have helped just press [Thank You + Rep.]...
Hello, i have dde error 42. Can you help me with this problem? I tried another injection pump, but it was with different code and engine didnt start at all. Now putted original pump back. Car starts but smoking even in idle and have no power. Pump code is 0281001827
Hello Mr. Black.,
I have the same ecu . Can i use your ecu eprom 24c04 dump with coinfig too , or do i have to send you the dump of my ecu ?
regards , Christophe
hello,
this is because the pump driver is broken, or that the pump has a different nr. If your pump for example ends with .....4005 it's a 136 bhp pump. maybe you have a mismatch ?
regards
Kindly advise i have a the same problem with my car 2001 E46 320D, How can access this file, is it possible to get it via email because here it keeps asking me to login.
If possible kindly send via my email
xxxxxxxxxxxxxxx
Sorry to bother you i can tell the tread is a bit old.
please help for check file becauce engine not start end have fault 42 memory
Bmw E46
can someone fix my bmw error 42 configuration eeprom file its of 1999 BMW e46 ecu 0281001445 320d
Thanks for help
Hello Mr Black, need help with the same problem, error 42, eprom and configuration, ecu the same 0281010205 eprom dump in attath, or pass good dump please
Hi, guys. I have some problem with my bmw 320d 2000, m47d20. I have a problem with EEROM 240C4. I can't download this file 24c04 eprom ecu original_with config.rar Can you send to my e-mail?
