You need to post a sysCheck19 report as instructed I that link so I can see which IOS's you've installed.
Hi All, Im hoping you can help me fix my Wii setup.
One of the kids did a system update and now the Loader GX app wont load the games. You hit start on the game, and the Wii goes back to the main menu.
So far I have:
Cleaned off my SD card.
Re-installed Bootmii through letterbox.
Put the latest Loader GX on my SD card.
Im a bit of a n00b at all this, my Wii is V 4.3E.
Still the same results.
Can anyone please help?
Thanks in advance.
Cheers
Keith
2010 Golf GTD (170)
Thanks Keith, will do.
Fresh of just now, thanks Keith!
sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
...runs on IOS58 (rev 6175).
Region: PAL (original region: AUS)
System Menu 4.3E (v514)
Drive date: 2007.02.13
Homebrew Channel 1.1.2 running on IOS58
HomebrewFilter ist nicht installiert
Hollywood v0x11
Console ID: 107326436
Boot2 v4
Found 116 titles.
Found 46 IOS on this console. 15 of them are stub.
IOS4 (rev 65280): Stub
IOS9 (rev 1034): No Patches
IOS10 (rev 768): Stub
IOS11 (rev 256): Stub
IOS12 (rev 525): No Patches
IOS13 (rev 1031): No Patches
IOS14 (rev 1031): No Patches
IOS15 (rev 1031): No Patches
IOS16 (rev 512): Stub
IOS17 (rev 1031): No Patches
IOS20 (rev 256): Stub
IOS21 (rev 1038): No Patches
IOS22 (rev 1293): No Patches
IOS28 (rev 1806): No Patches
IOS30 (rev 2816): Stub
IOS31 (rev 3607): No Patches
IOS33 (rev 3607): No Patches
IOS34 (rev 3607): No Patches
IOS35 (rev 3607): No Patches
IOS36 (rev 3607): No Patches
IOS37 (rev 5662): No Patches
IOS38 (rev 4123): No Patches
IOS40 (rev 3072): Stub
IOS41 (rev 3607): No Patches
IOS43 (rev 3607): No Patches
IOS45 (rev 3607): No Patches
IOS46 (rev 3606): No Patches
IOS48 (rev 4124): No Patches
IOS50 (rev 5120): Stub
IOS51 (rev 4864): Stub
IOS52 (rev 5888): Stub
IOS53 (rev 5662): No Patches
IOS55 (rev 5662): No Patches
IOS56 (rev 5661): No Patches
IOS57 (rev 5918): No Patches
IOS58 (rev 6175): USB 2.0
IOS60 (rev 6400): Stub
IOS61 (rev 5661): No Patches
IOS62 (rev 6430): No Patches
IOS70 (rev 6912): Stub
IOS80 (rev 6943): No Patches
IOS222 (rev 65280): Stub
IOS223 (rev 65280): Stub
IOS249 (rev 65280): Stub
IOS250 (rev 65535): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS254 (rev 65281): BootMii
BC v6
MIOS v10
Report generated on 2014/11/29.
As you may have read on here that's a typical sysCheck of a Wii that's only been softmodded as you have 15 IOS's that are Stub, you need to reduce that 15 down to 4 or 5.
Download ModMii6.3.1 and run ModMii.exe from Windows. Use the SU option from the main menu and find the location of the sysCheck.csv from the sysCheck which is on the root of the SD card. That will download all missing wads and apps to COPY_TO_SD sub folder just add all files and folders to the SD card.
ModMii only installed 2 d2x v8.0 wads download d2x v8 Final wad pack and put these in the wad folder on the SD card, install all 7 wads when you install the other wads.
Put the SD card back in the Wii and run Homebrew. Run IOS236 Installer v5 Mod first before you install any other wads. Multi Mod Manager (MMM) should be the first app listed select it and load it. Once running scroll down to WAD Manager and press 'A' that will default to all wads in the wad folder. If you want to install all wads shown just press 1 that will list all wads you want to install press 'A' again to install them all.
Watch for the Installed OK message after each one. If any don't say that message make a note of the wad name and back out. Scroll down to the wad that didn't install and press the + button the put a green + next to it then press 'A' to see that wads name listed then press 'A' to install again.
Download PriiLoader 0.7 add it to the SD card and run it from Homebrew and set it to block online and disc updates, you can turn off the 'A' safety prompt on startup I do.
If you have to update to 4.3 then the Shopping Channel may not work. If it doesn't without doing another system update don't bother just install my RVL-Shopping-21
Do another sysCheck to make sure everything installed correctly and post that.
Keith
2010 Golf GTD (170)
SgtGibbon (30th November, 2014)
You are a GOD
Thanks so much!
...runs on IOS58 (rev 6176).
Priiloader installed
Hollywood v0x11
Boot2 v4
Found 126 titles.
Found 54 IOS on this console. 4 of them are stub.
IOS11 (rev 16174): Trucha Bug, NAND Access
IOS12 (rev 526): No Patches
IOS13 (rev 1032): No Patches
IOS14 (rev 1032): No Patches
IOS15 (rev 1032): No Patches6
IOS17 (rev 1032): No Patches
IOS20 (rev 16174): Trucha Bug, NAND Access
IOS21 (rev 1039): No Patches
IOS22 (rev 1294): No Patches
IOS28 (rev 1807): No Patches
IOS30 (rev 16174): Trucha Bug, NAND Access
IOS31 (rev 3608): No Patches
IOS33 (rev 3608): No Patches
IOS34 (rev 3608): No Patches
IOS35 (rev 3608): No Patches
IOS36 (rev 3608): No Patches
IOS37 (rev 5663): No Patches
IOS38 (rev 4124): No Patches
IOS40 (rev 16174): Trucha Bug, NAND Access
IOS46 (rev 3607): No Patches
IOS50 (rev 16174): Trucha Bug, NAND Access
IOS52 (rev 16174): Trucha Bug, NAND Access
IOS53 (rev 5663): No Patches
IOS55 (rev 5663): No Patches
IOS56 (rev 5662): No Patches
IOS57 (rev 5919): No Patches
IOS58 (rev 6176): USB 2.0
IOS60 (rev 16174): Trucha Bug, NAND Access
IOS61 (rev 5662): No Patches
IOS70 (rev 16174): Trucha Bug, NAND Access
IOS80 (rev 16174): Trucha Bug, NAND Access
IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
IOS245[37] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS246[38] (rev 21008, Info: d2x-v8final): Trucha Bug, ES Identify, NAND Access
IOS247[53] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS248[55] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS251[58] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
BC v6
MIOS v10
Report generated on 2014/11/30.
Well there is nothing wrong with that sysCheck now, so are games working of an external mains power HDD?
Please click the Thanks button under the post that helped you?
Keith
2010 Golf GTD (170)
Yep, games all working. Thanks again!
