Results 1 to 8 of 8
    szkeptmen's Avatar
    Hungary
    Exclamation Audi - 8D0 959 655 J - internal error - 65535 - CR16MFR544
    Hi all,
    Need a little help to clear internal memory error...
    I have two airbag ecu's, both Bosch 0 285 001 276
    Soft: 00106
    Audi 8D0 959 655 J inside CR16 MFR544
    I read with Smok's crash eraser, but no tool can repair it
    Someone can help me ?
    Polak, wegier dwa bratanki i do szabli i do szklanki
    Croatia
    Hello
    Try this and report...
    If works press thanks button...
  3. The Following User Says Thank You to Mezz_cro For This Useful Post:
    rumen700 (11th June, 2019)
    Here is, try it
  5. The Following User Says Thank You to ivoo For This Useful Post:
    szkeptmen (6th December, 2014)
  6. #4
    autocargo's Avatar
    Hello. I've got this one and working good.
  7. The Following 3 Users Say Thank You to autocargo For This Useful Post:
    gyury9 (13th February, 2017), lucky-zg (5th May, 2017)
  8. #5
    levisdj's Avatar
    EcuLand
    Hi, please help clear 65535 internal control module memory error, from airbag module, same p/n from title, file read with fvdi by obd.Thanks!
    Mine is 655 F not J
  9. #6
    Jun 2020
    I will surely try this method, only I can't download the files listed above.
  10. #7
    Jul 2021
    What tool do u use to put the new dump inside the ecu? can I do it with vagcom or should I remove the eprom and put it in a eprom reader to modify it on HEXedit ?
  11. #8
    Nov 2017
    Dobruja
    This will do the job. Vag airbag reset tool. Under 10euros price.
    65535 dtc appears when battery get drained.
