Focus 1K78X and x-prog m problem
Results 1 to 8 of 8
    Sep 2014
    Default Focus 1K78X and x-prog m problem
    HI. I have problem with my x-prog m clone. I've done a lot of eep with this tool but now i have a focus 2007 dash with MC9S12H128 1K78X mask. I need to read eeprom from this mot. I'm fighting with this one about 5 hours and no success. Where's the problem ? Ext voltage 12V 2A connected. Connection from datasheet and xprog instruction. Maybe something wrong with xprog and it's time to buy other programmer. ?
    Meat-Head's Avatar
    Not sure, look on ny04. Certain focus with certain mask, you needs to lift a pin off the board, it should have a B D S M. Port on it
    Sep 2014
    on Nyo4 only same pinout picture like i've uploaded.
    I found b d s m connection here on DK and connect. no success
    Wrong diagram, that one is exclusively for H256. H128 is another one.
    Sep 2014
    Zmann could You help me, please ?
    Actually you are able to find the correct diagram yourself simply by looking at 'Show Connection Diagram' when select the device.
    Top Poster + dom8's Avatar
    Nov 2012
    Baltic states
    i read this dash and clone to other with xprog m and nyo4 pinout like c-max. no need add external power all read write no problem. just 4 wire solder, no lift pin.
    DK Veteran haingoben's Avatar
    Dec 2011
    Tana
    hi
    please send pict for reading!!
