Page 12 of 15 FirstFirst ... 2789101112131415 LastLast
Results 166 to 180 of 220
  1. #166
    Does anyone has an issue with 5.5.1, like you read successfully eerpom or MCU, then you want to read/wrige again, and software always hangs on Check Device..?
    Before it was working fine, this problem just started recently. Tried on 2 different PC - same.
    To get it working you need to replug device and restart the Xprog software, and again only for 1 time.
  2. #167
    Feb 2016
    Taiwan
    Hello everyone, my situation is the same ............
  3. #168
    Fec001's Avatar
    Default Atmega R/W issue
    Never program Atmega with Xprog. Anyone knows why are the Read and Write buttons grayed????? Blank check and erase device is ok successfully.
    On pics, port is unidefinied because xprog is unplugged. If plugged in and port is ok, problem is the same.
  4. #169
    micromax's Avatar
    South Poland
    select FILE / NEW PROJECT
    then PROJECT / FILES... and select file , next you see what you need.
  5. The Following User Says Thank You to micromax For This Useful Post:
    Fec001 (17th May, 2016)
  6. #170
    Fec001's Avatar
    Great, found that !!!! What about lock bits and fuse bits?
  7. #171
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    anyone have
    Xprog 5.5.1
    in hex for eprom and flash
  8. #172
    dadal's Avatar
    Aug 2015
    I have problem " Bootloader inistilisation error " in tms 370C036 ( tms from iaw 6r.30 twingo ,tool : xprog v5.55 clone with dongle ) I use adapter P/C:1 002-0002
    on this adapter written Plcc28 but it is an Plcc44 , is that right or I m wrong ?
    I want to downgrade to v.5.51..could anyone read this chip with v.5.51 ?
  9. #173
    Fec001's Avatar
    I have this error.. Anything what I try to read, get this message
    EDIT:
    Solved with setting lock and fuse bits right.
  10. #174
    sv2hqx's Avatar
    Jun 2014
    Default xprog issue
    hi to all
    i face the following issue
    i can read or write only once any mcu
    second time stuck on ''check device'' and only green led is on and i cant even close program
    can close only from task manager
    after restart working again but one time
    win7 32 bit
    couple weeks ago was working
    dont know if this was after an update
    solved
    bad exe file
    unzipped again
  11. #175
    Sep 2014
    problem register Solution? any idea ?
  12. #176
    hass42's Avatar
    Aug 2012
    USA
    Quote Originally Posted by Fec001 View Post
    EDIT:
    I got same error and checked and rechecked fuse and lock bits
    My xprog box had a dongle, if I program this to that box will it work without dongle? or work at all?
  13. #177
    EDIT:
    hello to all
    i have same probleme pls help
    best regards
  14. #178
    Oct 2015
    Hi to all, anyone can tell me about the new 5.60 version clone? Its stable and works good?
    Thanks!
  15. #179
    Sep 2016
    I tried with 5.5.0 with 5.5.5 and with 5.7 (this one works, but I dont have any access) and nothing works, hopefully this one does!
  16. #180
    BRASIL / SUL
    doubts, but should not be in all true? if someone tried to change from false to true, and it does not change is semrpe false. tell me if mine is a problem or WHAT would it be?
    My hardware is a 5.3, I'm trying to get to work with 5.5.1, but I have not resutado ok. if anyone can help. thank you.true x false.jpg
