Page 14 of 15 FirstFirst ... 49101112131415 LastLast
Results 196 to 210 of 218
  1. #196
    Oct 2016
    Default after i programmed my atmega by AVR
    what should I check or uncheck in avr fuse & lock bits
  2. #197
    Hello
    Help me Please
    I do atmega 64 with upa USB erase error
    Flash error
    What is it problems?
  3. #198
    Jun 2014
    xprog avr.jpgI found this.
  4. #199
    DK Veteran zoro1's Avatar
    Bulgaria,Sofia,Vidin
    I updatre my years ago ,working good on XP ,and 7 64 bit.I try some 555 soft from net ,but no working good.I use this with internet ON with no problems.I manage to add atmega 10 ISP port on one side for reprograming atmega inside xprog and no open it.Inside there is two ping mark GND ,on my AVR 910 programmer is conection to be able to program atmega.For special case/fuse bit wrong!/ i add Xtal1 to ISP too,if i lock my atmega !Thanks LAndre and Adam 28 for good JOB!!!But i was try to read MPC 551 ,read all ok /edc16c34 KIA/ then erase flash ,erase eeprom ,then try to write flash and there is error on 80,68,98 % -writing failed!Conection is standart BDM Bosch with ext 12 volt.
    Large nations behave like gangsters ,and young as prostitutes !
  5. #200
    Mar 2017
    I have updated and now I have the error unknown command software error
  6. #201
    xoom's Avatar
    Ylakiai
    Quote Originally Posted by memore34 View Post
    did you set lock bits?
  7. #202
    Tecdiag's Avatar
    Oct 2012
    Algeria
    hello all, please does someone know the pinout connection and lockbits, fusebits configuration to read atmega64 and update my XprogM with upaUsb .
    If you can not fix it, please leave it as it cameIF I HELPED YOU PUSH THANKS AND REP BUTTONS
  8. #203
    alfons37's Avatar
    I have update to 5.51 and all work, but i must restart software every time if i read one time. If i no do it hangs on reading. What is wrong?
  9. #204
    Dec 2018
    function?or not?
  10. #205
    Oct 2015
    Default 5.5.1.txt
    Hi, I am asking for 5.5.1.txt I can not download it. Thank you in advance
  11. #206
    Becoacamba's Avatar
    AnyWhere
    Quote Originally Posted by tom222 View Post
    IT'S WORKING RIGHT
  12. #207
    Jan 2016
    thanks, hope will be helpful
  13. #208
    Oct 2015
    Hello Adam, I was able to update but when I read any memory it gives me a message from unknown command, software error, do you know how I can solve ?? my xprog-m was version 5.84 clone but I couldn't find the certificate anymore ...
  14. #209
    Aug 2019
    Thanks!!!!
  15. #210
    Mar 2017
    TÜRKİYE
    I'M GETING A PROBLEM WITH ME I NEED TO DO WHAT HELP
