Behind dash little to right
sent from LG_G2
Hi got to have a look at a fox for a spare key, I belive pin code reading doesn't always work and on zed bull eprom/mcu they have fox and it's just a eprom, what I was hoping to find out is it hard to find the immo box and how difficult is it to remove just so I'm prepared.
thanks zip
sent from LG_G2
Actions speak louder than words
Ok thanks, so best remove dash/clocks and then just remove the immo box, it doesn't look like a massive box on zedbull so shouldn't be too hard I hope
thanks zip
It's little box with 93c56 eeprom so won't be hard . Good luck.
fox until 2008 has imobox you can read ?pin code by obd , sbb will do it,,, but your fox was produced , after 2008 , you need to read the dash / or ecu to get your pin code
It's a 2006/7 so will sbb clone do it? I forgot about trying sbb and even supervag pin reader but I'll give them a go
thanks zip
Hi been back and couldn't see the box at all, is it hidden?
hello my friend vw fox from 2005....see if your cluster is MM have motorola processor mc9s12h256 remove dash and read !
Hi thanks I thought that, I did take the dash out and saw it was MCU but didn't have time to start reading a MCU
Does anyone know the connections from my picture? I know it will be them 6 connections all together, also I don't think I've got a calc for fox or would a calc for VW beetle work as I have one for that MCU that's the same
thanks zip
RED VCC (5+) BLACK GND PINK BKGD YELLOW RESET
BusCan (4th April, 2022), martinracing (27th December, 2014), tiguan (21st December, 2014), vavrich (3rd February, 2019)
Thanks I'll give it a go, just hope I've got something that can calc the pin
zip
Hi never saw the other fox again but have another and it will not read using upa, normally don't have problems
tried with carprog as well and just flashes display but does not read
MC9S12H256CFV
2K78X
Hello guys,
It can be read this mcu with xprog on board conections?if yes can you give bdm connection ?
I will apreciate the effor.
Regards,dragos
If I help you dont forget to push thanks button
